Hello,
I’m trying to setup LE (./certbot-auto --webroot certonly --staging) using the staging option for the moment on the pointgraphics.ie , but I’m getting the following error:
DNS problem: NXDOMAIN looking up A for pointsgraphics.ie
Any ideas what this means?
I have the A record pointing to the correct IP address.
Regards,
Stephen
That domain does not seem to exist in the DNS.
$ dig pointsgraphics.ie
; <<>> DiG 9.10.3-P4-Ubuntu <<>> pointsgraphics.ie
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 33016
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;pointsgraphics.ie. IN A
;; AUTHORITY SECTION:
ie. 7200 IN SOA a.iedr.ie. tld-tech.iedr.ie. 2017060611 7200 7200 2592000 7200
;; Query time: 115 msec
;; SERVER: ::1#53(::1)
;; WHEN: Tue Jun 06 21:10:50 UTC 2017
;; MSG SIZE rcvd: 98
$ whois pointsgraphics.ie
% Rights restricted by copyright; http://iedr.ie/index.php/mnudomregs/mnudnssearch/96
% Do not remove this notice
% Not Registered - The domain you have requested (pointsgraphics.ie) is not a registered .ie domain name.
(I hasten to add that whois information is never guaranteed to be accurate or up-to-date.)
Are you sure you’re not misspelling the domain? Maybe it was just registered and it takes a few hours to start working?
schoen
June 6, 2017, 11:48pm
3
I’m guessing a typo between pointgraphics.ie (which does exist) and pointsgraphics.ie (which doesn’t)?
@mnordhoff , as Schoen pointed out the domain is pointgraphics.ie , see below…
; <<>> DiG 9.8.3-P1 <<>> pointgraphics.ie
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 53799
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 4, ADDITIONAL: 7
;pointgraphics.ie. IN A
;; ANSWER SECTION:
pointgraphics.ie. 3482 IN A 54.72.208.179
pointgraphics.ie. 172682 IN NS ns2.blacknight.com.
pointgraphics.ie. 172682 IN NS ns4.blacknight.com.
pointgraphics.ie. 172682 IN NS ns1.blacknight.com.
pointgraphics.ie. 172682 IN NS ns3.blacknight.com.
;; ADDITIONAL SECTION:
ns1.blacknight.com. 1603 IN A 78.153.212.176
ns2.blacknight.com. 123217 IN A 81.17.254.6
ns3.blacknight.com. 123217 IN A 162.88.60.11
ns4.blacknight.com. 123217 IN A 162.88.61.11
ns2.blacknight.com. 123217 IN AAAA 2a01:a8:dc3:3313::aaaa
ns3.blacknight.com. 123217 IN AAAA 2600:2000:1000::11
ns4.blacknight.com. 123217 IN AAAA 2600:2000:1001::11
That's not what the error message in your first post said, though. It said pointsgraphics.ie.
You also said "pointgraphics.ie" in your first post, which to be honest i missed...
Either way, there's a typo somewhere; maybe in the Certbot command you ran, or maybe in an HTTP redirect in the web server configuration or something.
rg305
June 8, 2017, 4:18am
6
O.K.
So rerun certbot with the correct domain name?
system
Closed
July 8, 2017, 4:19am
7
