DNS problem: NXDOMAIN but dig _acme-challenge.sbsiot.xyz works
My domain is: sbsiot.xyz
sudo ./certbot-auto certonly --manual --preferred-challenges=dns --email mckenna.tim@gmail.com --server https://acme-v02.api.letsencrypt.org/directory --agree-tos -d *.sbsiot.xyz
   Domain: sbsiot.xyz
   Type:   dns
   Detail: DNS problem: NXDOMAIN looking up TXT for
nginx 1.10.3
ubuntu 16.04
n3servers
I can login to a root shell on my machine
I’m not using a control panel
Certbot 0.38.0
once the CNAME record updates dig gives me the correct challenge text
dig -q=txt _acme-challenge.sbsiot.xyz txt +short
92.242.140.21
wymew9dvd5emwf5721vbsj2b3zwxfygstz-p3o_eaow.
(nslookup fails though
nslookup -q=txt _acme-challenge.sbsiot.xyz.
Server:         192.168.1.1
Address:        192.168.1.1#53
`** server can't find _acme-challenge.sbsiot.xyz: NXDOMAIN)`
Hi @mckennatim,
This is a kind of obscure one in terms of the way that different software will handle it, but you've created a CNAME record instead of a TXT record on your DNS server. You should find where you did that and replace it with a TXT record instead.
