Fatal: All Name Server IPv4 addresses from the same subnet. Check Technical requirements for authoritative name servers to learn some basics about name server configurations. If you manage these name servers, fix it. If it's your provider, change your provider.:
X
Fatal: Only one Name Server IPv4 address found. Check Technical requirements for authoritative name servers to learn some basics about name server configurations. If you manage these name servers, fix it. If it's your provider, change your provider.
IANA:
Minimum number of name servers
There must be at least two NS records listed in a delegation, and the hosts must not resolve to the same IP address.
Both of your name servers have the same ip address. That's fatal. Change that.
My question is that 2 or 3 weeks back with the same configuration I got A the result of the test, and now I got X.
I did not changed anything from the last time I ran this check. Last time with both nameservers pointing to the the same IP address I got an A.
Is this something that changed recently?
I have only one machine and I host my DNS on that machine, so I do not have two IP addresses. What should I do?
Added some new things (some weeks earlier), saw a lot of buggy configurations (different name servers with the same ip address or from the same subnet), then changed the calculation.
Why do you host your own name servers if you aren't able to have different ip addresses in different locations?
I host my own nameserver because I wanted to learn and experiment how to set up BIND on linux. I would like to keep at least one nameserver.
For the second one, can I use a secondary DNS?
Many authoritative name servers are answering now, but you have to update the NS records in the zone itself to match the delegated name server entries from the zone apex (ccTLD ro.).
Fatal: Inconsistency between delegation and zone. The set of NS records served by the authoritative name servers must match those proposed for the delegation in the parent zone.: nsge2.artphotos.ro (31.7.187.185): Delegation: ns1.1984hosting.com, ns2.1984.is, ns2.1984hosting.com, nsge1.artphotos.ro, nsge2.artphotos.ro, Zone: nsge1.artphotos.ro, nsge2.artphotos.ro
Can you please check again?
When I run dig artphotos.ro NS
I get
;; ANSWER SECTION:
Thank you.
P.S. I kept only one NS outside of my network. I added it to my Zone as NS as well as an A record for it.
Is there anything else I need to do?
I understand what you say. However, I do not think that is a problem. My problem is
The set of NS records served by the authoritative name servers must match those proposed for the delegation in the parent zone.: ns1.1984hosting.com (185.112.145.13):
Delegation: ns1.1984hosting.com, nsge1.artphotos.ro, nsge2.artphotos.ro,
Zone: nsge1.artphotos.ro, nsge2.artphotos.ro.
Name Servers defined in Delegation, missing in Zone: ns1.1984hosting.com.
This is what I think I have to solve, but I do not know how.
The issue is simple to solve. First of all, you need at least two name servers (with different IP addresses) to function. For the simplicity select precisely two: nsge1.artphotos.ro and ns1.1984hosting.com.
So you have to add into your DNS zone:
@ 38400 IN NS nsge1.artphotos.ro.
@ 38400 IN NS ns1.1984hosting.com.
And no other NS entries.
When this is fine (both the two servers authoritatively answer the same expected NS list), you have to update the nameserver list at your registrar for the zone artphotos.ro to precisely match the above two name servers. (You probably has to define a name server IP entry [for glue record] at the registrar for nsge1.artphotos.ro, but that is most likely already done.)
This is the part that I have now in my artphotos.ro zone
I do have glue records at my registrar for nsge1 and nsge2 with the corresponding IP addresses.
I also have a glue record without the IP for ns1.1984hosting.com. because it is hosted by a different domain.
I host my own primary DNS with nsge and I wanted to use 1984hosting.com. as my secondary DNS.
1.Is it something else I’m missing?
2. However, I do not see how the nsge2.artphotos.ro is an issue just because is there, because the requirement is for 2 different IP addresses which is covered by nsge1 and ns1
The name server list does no seem to be the same on the two name servers. Did you increase the serial number of the SOA record on the master that the slave name server be able to update its zone file?
It may or may not be a problem. The solution I proposed is fail safe in that respect.
The NS list is not the same on the two name servers. You have to increase the serial number of the SOA record on the master to trigger zone download on the slave server.
Problem solved.
I used 1984hosting.com as a secondary.
The thing is that I only had to add a NS record in my zone.
One does not need to add an A record with the NS.
Of course we have to allow transfers to the IP suggested by 1984hosting.com
