--dns-cloudflare with no options-ssl-nginx.conf and ssl-dhparams.pem
test.domain.com.br
certbot certonly --dns-cloudflare --dns-cloudflare-credentials /etc/animati/certbot/cloudflare.ini -d test.domain.com.br
success.
nginx version: nginx/1.20.2
Ubuntu 20.04.3 LTS
no
certbot 1.18.0
problem is:
the command --dns-cloudflare without --nginx is not creating the file "/etc/letsencrypt/options-ssl-nginx.conf" and the file "/etc/letsencrypt/ssl-dhparams.pem"
how could I create this files if no run certbot with --nginx ?
how could I configure nginx without this files?
You can separately select the authenticator and installer plugins with the -a and -i options respectively, to combine the dns-cloudflare authenticator and nginx installer.
You can read more about combining plugins in the certbot user manual here: User Guide — Certbot 1.21.0 documentation
