My domain is: ideaman924.com
I ran this command: certbot certonly --dns-cloudflare --dns-cloudflare-credentials ~/.secrets/cloudflare.ini -d ideaman924.com -d *.ideaman924.com -i nginx
Plugins selected: Authenticator dns-cloudflare, Installer nginx
dns-01 challenge for ideaman924.com
Waiting 10 seconds for DNS changes to propagate
/etc/letsencrypt/live/ideaman924.com/fullchain.pem
/etc/letsencrypt/live/ideaman924.com/privkey.pem
Your cert will expire on 2020-05-05. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew *all* of your certificates, run
"certbot renew"
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
My web server is (include version): nginx version: nginx/1.14.2
The operating system my web server runs on is (include version): Debian 10.2
My hosting provider, if applicable, is: DigitalOcean
I can login to a root shell on my machine: Yes
Iām using a control panel to manage my site: No
The version of my client is: certbot 0.31.0
Basically what the title says. After installation, certbot
does not modify the nginx server configuration directives, even if I pass the -i nginx
command-line parameter. Therefore, SSL on nginx remains broken and the website does not pass the SSL test. What am I doing wrong?
