Detail: DNS problem: NXDOMAIN looking up A for www.ordyum.com
My domain is:ordyum.com
I ran this command:sudo certbot --nginx -d ordyum.com -d www.ordyum.com
It produced this output:Failed authorization procedure. www.ordyum.com (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for www.ordyum.com
My web server is (include version):nginx
The operating system my web server runs on is (include version):ubuntu 16.04
My hosting provider, if applicable, is:digitalocean
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
You don’t have an A record for your www version of domain.
Please add it to your digital ocean control panel.
I had already A record and Cnames : see screenshot below
You also need to add www and point to the same ip in order to use www for your cert.
Thank you
Thank you so much <3
In order to use it in any way to be exact :stuck_out_tongue:
