My domain is: nas.mg-bgrahic…
I ran this command:sudo ./certbot-auto certonly
Domain: nas.mg-bgraphic…
Type: connection
Detail: Could not connect to …external ip…
Raspbian
At this moment you can only visit the website in httpS
I got the file now the only problem now is whenn i put the following line:
ssl_certificate /etc/letsencrypt/live/nas.mg-bgraphic…/fullchain.pem;
(instead of the line that was there :
ssl_certificate /etc/nginx/cert.pem;
ssl_certificate_key /etc/nginx/cert.key;
in
192.168.2.33 is a private IP address for you local LAN, that isn't routable via the public internet. So, if you are trying to create a certificate for that IP, certbot won't make one.
Depending on your requirements, you have two options:
Setup NAT on your router to forward port 80 and port 443 traffic from your modem's public IP to your LAN device's private IP. Then change your DNS A name entry to the public IP address. Then try recreating the certificate.
If you do actually need to create a valid certificate for a private IP address, this tutorial explains how: Redirecting…
