Will certbot work with private IP address
My domain is: enacom.com.au
I ran this command: "sudo certbot --nginx -d grafana.enacom.com.au -d www.grafana.enacom.com.au"
Requesting a certificate for grafana.enacom.com.au and www.grafana.enacom.com.au
http-01 challenge for grafana.enacom.com.au
http-01 challenge for www.grafana.enacom.com.au
Challenge failed for domain grafana.enacom.com.au
Challenge failed for domain www.grafana.enacom.com.au
Domain: grafana.enacom.com.au
Type: dns
Detail: no valid A records found for grafana.enacom.com.au; no valid AAAA records found for grafana.enacom.com.au
Domain: www.grafana.enacom.com.au
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for www.grafana.enacom.com.au - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for www.grafana.enacom.com.au - check that a DNS record exists for this domain
The operating system my web server runs on is (include version): N/A
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):N/A
certbot --version
certbot 2.5.0
Yes, but only using the dns-01 challenge, as the http-01 and tls-alpn-01 require access to the IP address and thus the IP address needs to be public. But the dns-01 challenge doesn't require the IP address, just access to the DNS zone.
Also, FYI:
nslookup grafana.enacom.com.au 8.8.8.8
Server:  dns.google
Address:  8.8.8.8
Non-authoritative answer:
Address:  10.10.20.50
nslookup www.grafana.enacom.com.au 8.8.8.8
Server:  dns.google
Address:  8.8.8.8
*** dns.google can't find www.grafana.enacom.com.au: Non-existent domain
The DNS challenge should work for you.
Note that this would mean you can't use --nginx to obtain your certificate.
https://eff-certbot.readthedocs.io/en/stable/using.html#getting-certificates-and-choosing-plugins
