Deleted cerbot certificates and now facing issue
https://suvarnakar.store/
Many commands including delete certbot, update certbot, sudo certbot etc
sudo cat /var/log/letsencrypt/letsencrypt.log
2022-03-05 14:06:02,639:DEBUG:certbot.main:certbot version: 0.31.0
2022-03-05 14:06:02,640:DEBUG:certbot.main:Arguments:
2022-03-05 14:06:02,640:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2022-03-05 14:06:02,654:DEBUG:certbot.log:Root logging level set at 20
2022-03-05 14:06:02,655:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2022-03-05 14:06:02,655:DEBUG:certbot.plugins.selection:Requested authenticator None and installer None
2022-03-05 14:06:02,772:ERROR:certbot.util:Error while running apache2ctl configtest.
Action 'configtest' failed.
apache2: Syntax error on line 225 of /etc/apache2/apache2.conf: Syntax error on line 41 of /etc/apache2/sites-enabled/suvrnakar-le-ssl.conf: Could not open configuration file /etc/letsencrypt/options-ssl-apache.conf: No such file or directory
2022-03-05 14:06:02,772:DEBUG:certbot.plugins.disco:Misconfigured PluginEntryPoint#apache: Error while running apache2ctl configtest.
File "/usr/lib/python3/dist-packages/certbot_apache/configurator.py", line 2212, in config_test
util.run_script(self.option("conftest_cmd"))
File "/usr/lib/python3/dist-packages/certbot/util.py", line 86, in run_script
raise errors.SubprocessError(msg)
certbot.errors.SubprocessError: Error while running apache2ctl configtest.
File "/usr/lib/python3/dist-packages/certbot/plugins/disco.py", line 132, in prepare
self._initialized.prepare()
File "/usr/lib/python3/dist-packages/certbot_apache/configurator.py", line 235, in prepare
self.config_test()
File "/usr/lib/python3/dist-packages/certbot_apache/configurator.py", line 2214, in config_test
raise errors.MisconfigurationError(str(err))
certbot.errors.MisconfigurationError: Error while running apache2ctl configtest.
2022-03-05 14:06:02,776:DEBUG:certbot.plugins.selection:Single candidate plugin: * apache
Description: Apache Web Server plugin
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: apache = certbot_apache.entrypoint:ENTRYPOINT
Initialized: <certbot_apache.override_debian.DebianConfigurator object at 0x7f7fdee039b0>
Prep: Error while running apache2ctl configtest.
2022-03-05 14:06:02,777:DEBUG:certbot.plugins.selection:Selected authenticator None and installer None
ubuntu@ip-172-31-28-223:/var/www/html$
self.config_test()
For sudo cerbot:
sudo certbot
Certbot doesn't know how to automatically configure the web server on this system. However, it can still get a certificate for you. Please run "certbot certonly" to do so. You'll need to manually configure your web server to use the resulting certificate.
Apache
ubuntu 18.04
AWS
no
certbot 0.31.0
Go on line 41 of that file and remove that include. (or just disable that virtualhost)
Please see the Certbot documentation about deleting certificates: User Guide β€” Certbot 1.24.0 documentation
This is also true for related files like the options-ssl-apache.conf.
Bottom line is: you shouldn't have deleted those files without fixing/removing the references to those files in your Apache configuration files.
Easiest way to fix it is to fetch /etc/letsencrypt/ from a recent backup. You DID make a backup when you deleted /etc/letsencrypt/, right?
I assume that's what the certbot rollback command is for. But I have never actually seen it in action.
I'm not sure if certbot rollback would work when Apache itself isn't working..
Also, rollback to what? Maybe the apache plugin has modified the configuration multiple times. Maybe it'll do more damage, not sure.
No, it probably won't even start if you obliterated /etc/letsencrypt
You can tell it how many times to go back.
But then you need to know how far to go back. Personally, I wouldn't use it. I would have absolutely no clue what Certbot would rollback into.
Neither would I. But then, I wouldn't use an installer plugin either. :smiley:
After removing include files.
I ran sudo certbot and get the error below
I also checked DNS A and it is showing server ip
:ERROR
Failed authorization procedure. www.suvarnakar.store (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.suvarnakar.store/.well-known/acme-challenge/hni9mLFbgaioHGI4GNF2LhSdlgA2R7OKEEAaftsT6iY: Timeout during connect (likely firewall problem), suvarnakar.store (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://suvarnakar.store/.well-known/acme-challenge/KvFouN7-odDr3kOXzsZ-G3NKloTuUR1vzurluUFzeQ0: Timeout during connect (likely firewall problem)
    Domain: www.suvarnakar.store
    Type: connection
    Detail: Fetching
    Domain: suvarnakar.store
    Type: connection
    Detail: Fetching
  • Your account credentials have been saved in your Certbot
Is your webserver actually running?
What command did you use to invoke certbot?
I ran it and now facing error below
ubuntu@ip-172-31-28-223:~$ systemctl status apache2.service
● apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor preset: enabled)
Drop-In: /lib/systemd/system/apache2.service.d
└─apache2-systemd.conf
Active: active (running) since Sat 2022-03-05 18:07:01 UTC; 20s ago
Process: 17274 ExecStart=/usr/sbin/apachectl start (code=exited, status=0/SUCCESS)
Main PID: 17293 (apache2)
Tasks: 7 (limit: 1135)
CGroup: /system.slice/apache2.service
β”œβ”€17293 /usr/sbin/apache2 -k start
β”œβ”€17298 /usr/sbin/apache2 -k start
β”œβ”€17299 /usr/sbin/apache2 -k start
β”œβ”€17300 /usr/sbin/apache2 -k start
β”œβ”€17301 /usr/sbin/apache2 -k start
β”œβ”€17302 /usr/sbin/apache2 -k start
└─17320 /usr/sbin/apache2 -k start
Mar 05 18:07:01 ip-172-31-28-223 systemd[1]: Starting The Apache HTTP Server...
Mar 05 18:07:01 ip-172-31-28-223 systemd[1]: Started The Apache HTTP Server.
netstat -nltp
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN -
tcp6 0 0 :::80 :::* LISTEN -
tcp6 0 0 :::22 :::* LISTEN -
tcp6 0 0 :::443 :::* LISTEN -
ubuntu@ip-172-31-28-223:~$ sudo certbot --apache
1: suvarnakar.store
2: www.suvarnakar.store
blank to select all options shown (Enter 'c' to cancel): 1,2
Requesting a certificate for suvarnakar.store and www.suvarnakar.store
Type: connection
Detail: Fetching http://suvarnakar.store/.well-known/acme-challenge/g9a4ZWbY3BNWY6gAjsJ9zdD2QhBJOHMOin3KEYoyoQM: Timeout during connect (likely firewall problem)
Type: connection
Detail: Fetching http://www.suvarnakar.store/.well-known/acme-challenge/3MQz2PsyP5HLB0-AL2j-PG0rkpJDH06fYCJAaGsFtwY: Timeout during connect (likely firewall problem)
Also I dont have backup of those deleted files. :disappointed_relieved:
It looks like your webserver is only listening on ipv6 but you don't have an AAAA record. Is this on purpose?
not sure about that should I add AAAA record?
Eventually, sure.
I'd first make sure your webserver listens on ipv4.
I recently was corrected on this same issue. Some systems show tcp6 but actually indicates is listening on both.
Also, need sudo netstat ... to see all columns of datea
So was I, but I remember it the opposite way. (show tcp but mean both)
Ubuntu shouldn't be one of those, tho.
Actually, 18.04 could be one of those:
# nmap -p80,443  www.suvarnakar.store
Starting Nmap 7.80 ( https://nmap.org ) at 2022-03-05 19:36 CET
Nmap scan report for www.suvarnakar.store (3.129.141.202)
Host is up (0.10s latency).
rDNS record for 3.129.141.202: ec2-3-129-141-202.us-east-2.compute.amazonaws.com
PORT    STATE    SERVICE
80/tcp  filtered http
443/tcp open     https
Nmap done: 1 IP address (1 host up) scanned in 2.17 seconds
# nmap -p80,443  suvarnakar.store
Nmap scan report for suvarnakar.store (3.129.141.202)
Host is up (0.097s latency).
PORT    STATE    SERVICE
443/tcp open     https
Nmap done: 1 IP address (1 host up) scanned in 2.05 seconds
80 closed and 443 open? Webserver not listening?
Getting Below Error
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see Rate Limits - Let's Encrypt
What was your command?
Try adding --dry-run or --test-cert
Also, what were the errors before this? (five in the last hour alone)
Check that your website works without https, please.
Command with full error
sudo certbot certonly --apache
1: suvarnakar.store
