Ok, you should wait 1 hour. Use that hour making sure your website works on http (without encryption).
I am trying but not able to figure out how I can allow http. Do you have any idea?
Look at your EC2 Security Group and make sure port 80 is allowed. Looks like you allow port 22 and 443 so do the same as for those.
I have solved issue and everything is working fine!!
@uttampatel007 I see you got a cert yesterday and that HTTPS to your server is working. So that's great.
But, your port 80 is closed again. That will prevent you from renewing your cert. And, it will block anyone that tries to use HTTP to connect to your site.
Let's Encrypt recommends keeping port 80 open always. That is good practice for many reasons.
@MikeMcQ Thank you for your suggestions. I have opened the http port 80.
