cURL error 60 when trying to connect to self
corp.bygeorgenet.me
curl -v https://corp.bygeorgenet.me
If I run the curl command on the server where nginx that hosts https://corp.bygeorgenet.me/ is running I get this output
*   Trying 116.203.20.196:443...
* TCP_NODELAY set
* Connected to corp.bygeorgenet.me (116.203.20.196) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (OUT), TLS alert, unknown CA (560):
* SSL certificate problem: unable to get local issuer certificate
* Closing connection 0
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
but when I try it from any other machine, everything is absolutely fine.
nginx version: nginx/1.18.0 (Ubuntu)
Hetzner
Yes
No
I use acme.sh
Some other useful info
root@venus-de:~# ifconfig | grep inet
        inet 116.203.20.196  netmask 255.255.255.255  broadcast 116.203.20.196
        inet6 fe80::9400:ff:fe2b:eed6  prefixlen 64  scopeid 0x20<link>
        inet6 2a01:4f8:c2c:b72::1  prefixlen 64  scopeid 0x0<global>
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
root@venus-de:~# traceroute corp.bygeorgenet.me
traceroute to venus.de.srv.bygeorgenet.me (116.203.20.196), 64 hops max
  1   116.203.20.196  0.003ms  0.001ms  0.001ms
Your server isn't sending the intermediate certificate.
Okay, I'll try using fullchain.cer!
Hi @gbougakov
there runs a check of your domain - https://check-your-website.server-daten.de/?q=corp.bygeorgenet.me
Openssl says: The intermediate certificate is missing.
PS: Yep, now the check is ready:
Chain - incomplete
	1	CN=corp.bygeorgenet.me
Thanks guys, you saved me so many hours of investigating! Really appreciate it, everything works now :heart:
