Hello.
I have several subdomains on a single computer (server1). I want get the SSL certificate. On another computer (server 2) I have other subdomains of the same domain that had on the server 1. Within a month server1 will move to another team and would like to keep that certificate.
I wanted to know if I get just as certificates on a single computer with multiple subdomains?
Also if on the same computer I can have several certificates?
And when I can make migration continue to have the certificates.
Thank you very much
You can do whichever option you prefer. To answer your specific questions
Yes, that's perfectly possible.
Yes
Yes, you can continue to have the certificates on 2 different computers.
for multiple domain
certbot-auto --apache -d example.com -d price.example.com auto.example.com car.example.com
Is correct?
Thanks
You need a "-d" for each domain
certbot-auto --apache -d example.com -d price.example.com -d auto.example.com -d car.example.com
Another question.
I think on a server certificate with a subdomain price.example.com
Then over time I think another certificate with subdomain auto.example.com
certbot-auto --apache -d example.com -d auto.example.com
You can do so, or should be done all at once.
certbot-auto --apache -d example.com price.example.com -d auto.example.com -d car.example.com
Thanks
Ideally, do it all correctly the first time
If you want to add domains to a certificate then use the --expand flag
see https://certbot.eff.org/docs/using.html#re-running-certbot
There was no documentation found.
Thanks.
