Create SSL certificates for CouchDB
Hello,
I am using CouchDB and trying to issue a certificate for my domain.
NOTE: my domain isn't being hit by the rate limit, I verified it. (I'll refer to my domain as "the.actual.domain") I'm also using the --test-cert flag, to not create useless production certs.
The issue is that I can't seem to make it work. When I read the CouchDB docs about SSL, I understand that the service has it's own webserver, so it can handle certificates. I tried to generate Let's encrypt certificates for my domain, which I then specified the files path into my CouchDB config (as specified in their docs). Restarted, then tried to go to my machine
certbot certonly --test-cert --webroot -w /var/www/html --config-dir /opt/couchdb/letsencrypt --logs-dir /opt/couchdb/var/log -d the.actual.domain
Output
(ref: /opt/couchdb/letsencrypt/renewal/the.actual.domain.conf)
What would you like to do?
1: Keep the existing certificate for now
2: Renew & replace the certificate (may be subject to CA rate limits)
Renewing an existing certificate for the.actual.domain
Certificate is saved at: /opt/couchdb/letsencrypt/live/the.actual.domain/fullchain.pem
Key is saved at:         /opt/couchdb/letsencrypt/live/the.actual.domain/privkey.pem
This certificate expires on 2022-06-03.
Certbot has set up a scheduled task to automatically renew this certificate in the background.
Using lighttpd v1.4.64 as webserver
The server runs Ubuntu 20.04
The server machine is hosted at DigitalOcean
I can login as root.
Using certbot v1.24.0
Could someone point out some guidelines on how I can setup an SSL certificates for a CouchDB server?
Any help is appreciated, and don't hesitate to ask for more information.
Hi @Lanhild,
So, after generating a non-test certificate from Let's Encrypt, you did the part they describe like
[ssl]
enable = true
cert_file = /etc/couchdb/cert/couchdb.pem
key_file = /etc/couchdb/cert/privkey.pem
where /etc/couchdb/cert/couchdb.pem is replaced by the Let's Encrypt fullchain.pem and /etc/couchdb/cert/privkey.pem is replaced by the Let's Encrypt privkey.pem? And then restarted or reloaded CouchDB?
And what kind of error or behavior do you see after that when trying to connect?
It seems in the CouchDB documentation that they were envisioning that you use CouchDB as its own web server, not an external one, or did I misunderstand that?
Oh my, thanks for the fast reply.
Indeed, I did all the steps as described in their docs (just like you described in your message). I also tried with and without lighttpd, and both methods didn't work.
Without lighttpd: I removed the flag --webroot -w /var/www/html to have this command;
certbot certonly --test-cert --config-dir /opt/couchdb/letsencrypt --logs-dir /opt/couchdb/var/log -d the.actual.domain
The output:
Saving debug log to /opt/couchdb/var/log/letsencrypt.log
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
When I try to connect, I get an SSL_ERROR_SYSCALL, without more information.
The thing is, I don't really know what the precise steps are to setup a certificate for CouchDB, whether I'm using it's own web server or another.
P.S
I also tried a self signed certificate, and it works, but that is of no use in a production environment.
It could be a permission error?
Looking at the linked documentation, this stands out to me:
chown couchdb privkey.pem couchdb.pem
So, I am guessing that CouchDB doesn't run as root (or run as root and drop privileges, like nginx and Apache do).
You might have to write a --deploy-hook to copy + chown the certificates.
With which client software? Can you also try with curl or openssl s_client?
Did you remove the --test-cert part at least once in order to get a genuine publicly-trusted certificate to configure on your service?
Verified, and CouchDB has all the permissions over the certs files.
I'm uncertain about how to use that --deploy-hook flag, isn't that used for certificates renewal?
The certificate doesn't seem to be the problem here, but maybe my config?
Tried with lighttpd and without (using simply couchdb) and both methods give me the same SSL_ERROR_SYSCALL.
Maybe I am not generating the certificates the proper way?
The last method I tried is generating a Let's Encrypt standalone cert, and as described in CouchDB docs, specify the path to the files in the config. I also verified, and couchdb has full permissions over these files.
The command I used:
certbot certonly --test-cert --config-dir /opt/couchdb/letsencrypt --logs-dir /var/log/couchdb -d the.actual.domain
the output:
My config for [ssl] in CouchDB
[ssl]
enable = true
cert_file = /opt/couchdb/letsencrypt/live/the.actual.domain/fullchain.pem
key_file = /opt/couchdb/letsencrypt/live/the.actual.domain/privkey.pem
Managed to make it work by using nginx.
Now I don't have anymore issues with certificate issuance. I just need to find path to my webroot for nginx, as if I go to https://the.actual.domain/_utils, I get a 404. (./_utils being the homepage of CouchDB)
You cannot use fullchain.pem it looks like.
You have to use cert.pem and chain.pem separately.
The option you're missing is cacert_file
https://docs.couchdb.org/en/3.2.0/config/http.html#https-ssl-tls-options
The certificate now works. The issue I have is that when I go to my url https://the.actual.domain, I arrive on the normal landing page of CouchDB;
Which describes some details of your installation. Up to there, nothing extraordinary. Now, if I try to go to https://the.actual.domain/_utils (_utils being the dashboard of CouchDB), I land on a 404 from nginx. Which makes me assume that I put the wrong web root path in the nginx config?
My config;
root /opt/couchdb/share/www;
Contents of /opt/couchdb/share/www;
dashboard.assets    docs    index.html
What should I do to resolve that 404 error?
You're making it difficult by not sharing your domain.
Is Nginx behaving like a reverse proxy? With what config?
Are you sure you don't want to configure couchdb to use the certificate directly? Try with this config:
[ssl]
enable = true
cert_file = /opt/couchdb/letsencrypt/live/the.actual.domain/cert.pem
cacert_file = /opt/couchdb/letsencrypt/live/the.actual.domain/chain.pem
When directly using CouchDB to use the certificate, it simply doesn't work. (gives the SSL_ERROR_SYSCALL)
My nginx config:
        listen 6984 ssl default_server;
        listen [::]:6984 ssl default_server;
        server_name the.actual.domain;
                proxy_pass http://localhost:5984;
                proxy_redirect off;
                proxy_set_header Host $host;
                proxy_buffering off;
                proxy_set_header X-Forwarded-Ssl on;
                try_files $uri $uri/ =404;
ssl_certificate /opt/couchdb/letsencrypt/live/the.actual.domain/fullchain.pem;
ssl_certificate_key /opt/couchdb/letsencrypt/live/the.actual.domain/privkey.pem;
ssl_protocols SSLv3;
ssl_session_cache shared:SSL:1m;
port 6984 being the HTTPS port for CouchDB. I tried with 443 as well in the nginx config but it doesn't change anything.
I just don't know why this 404 is happening. Any clues about the value I should put as the web root path?
What the f*cking f*ck. This probably has something to do with it.
Use
or
    ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
if you really have to.
None, you should not have a root there. You already have a proxy_pass directive, I am not even sure about the try_files directive.
My similar config looks like this:
upstream lampone {
        server 10.9.1.5 max_fails=0; # wireguard
        server 10.9.0.5 max_fails=0 backup; # tinc
        server_name lampone.example.com;
        include snippets/listen;
        include snippets/ssl_conf;
        include snippets/ssl_cert_lampone;
                root /var/www/html;
                try_files $uri $uri/ @lampone; # <- this is location lampone
        location @lampone {
                proxy_pass http://lampone; # <- this is upstream lampone
                include snippets/proxy_conf;
Lol. Sorry if I look like a noob, but it's because I'm pretty new to issuing certs.
I modified to
as you said.
I really think you should try using the certs in couchdb directly, as I said before. Unless you have some reason to use nginx in front of it, that is.
Still get the same SSL_ERROR_SYSCALL, even when using the certs directly in the CouchDB config.
You should really give us the actual domain name.
Are you sure? How did you achieve this?
When I just tried to install CouchDB and point it to my Certbot certificate, it fails when I try and connect on the SSL port. Tracing what CouchDB is doing, the issue is indeed due to permissions:
root@british-guest:~# strace -e trace=openat -ff -p $(pidof beam.smp) 2>&1
strace: Process 4002 attached with 35 threads
[pid  4065] openat(AT_FDCWD, "/etc/letsencrypt/live/british-guest.bnr.la/fullchain.pem", O_RDONLY) = -1 EACCES (Permission denied)
and I got the same error as you when trying to access CouchDB's SSL port in a browser.
Then as soon as I used ACLs to grant access:
root@british-guest:~# setfacl -Rdm u:couchdb:rx /etc/letsencrypt/{live,archive}
root@british-guest:~# systemctl restart couchdb
everything started working.
It's both for renewal and for the initial certificate issuance. You can point to a shell script which could perform various tasks such as:
  • Copying the certificate files to /opt/couchdb/etc
  • Giving the certificate files appropriate permissions
  • Reloading/restarting CouchDB (if necessary to reload the certificate)
