i have linux aws machine
step for create certificate
- have registered my record dns on
(http://niculine.ddns.net/) correctly responde my custom page apache2
i have permission chmod +777 -R on apache2 /var/www/html
and i created subdir .well-known/acme-challenge with all permission
my host config
<VirtualHost *:80>
ServerName niculine.ddns.net
DocumentRoot "/var/www/html"
</VirtualHost>
i have used a docker image
sudo docker run -it --rm --name certbot -v "/etc/letsencrypt:/etc/letsencrypt" -v "/var/lib/letsencrypt:/var/lib/letsencrypt" certbot/certbot certonly --standalone --preferred-challenges http -d niculine.ddns.net
result error:
Requesting a certificate for niculine.ddns.net
http-01 challenge for niculine.ddns.net
Challenge failed for domain niculine.ddns.net
Domain: niculine.ddns.net
Detail: Invalid response from
http://niculine.ddns.net/.well-known/acme-challenge/QQgM_1MAHEKlKF6KQDoXzs7SxqSZ658SCJIvOcH17zM
[54.74.176.126]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML
2.0//EN\">\n<html><head>\n<title>404 Not
Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p"
Hello @nturri1306,
If you use standalone parameter, certbot will start a server on port 80 but seems you have an Apache server already listening on port 80 so it won't work. If you still want to use standalone you should stop your web server first.
Cheers,
sahsanu
hello tnx for you response
i have this question my apache2 is running in another docker container and correct respose with port 80
if change command option 1 receive this
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
Please enter in your domain name(s) (comma and/or space separated) (Enter 'c'
to cancel): niculine.ddns.net
Input the webroot for niculine.ddns.net: (Enter 'c' to cancel): /var/www/html/
/var/www/html/ does not exist or is not a directory
***** /var/www/html/ is directory of apche2 contanier
question EXIST A VERSION OF CERTBOT FOR AWS MACHINE?
certbot should be able to write in /var/www/html/ but if that dir is not available on the host, only on the docker container side you can't validate your domain. I don't use docker so can't advise about how to allow the host to write to the dir inside the docker container.
If AWS Linux doesn't distribute certbot as a package then you could check whether you can install snap there and if you can you could use the certbot snap version... or you could use another client like acme.sh
hello i've modify my run container and now it's ok
sudo docker run -it --rm --name certbot -v /var/www/html:/var/www/html -v "/etc/letsencrypt:/etc/letsencrypt" -v "/var/lib/letsencrypt:/var/lib/letsencrypt" certbot/certbot certonly -d niculine.ddns.net
