Cpanel/WHM Installation Problem ? Help
SSH üzerinden aşağıdaki kodla kurulum yaptım.
/scripts/install_lets_encrypt_autossl_provider
Ancak hata alıyorum. Bu hatayı daha önce almamıştım ?
A warning occurred while processing this directive. [close]
Failed to load information for the AutoSSL module “LetsEncrypt”: Cpanel::Exception::ACME::Protocol/(XID w466wk) The ACME function “https://acme-v01.api.letsencrypt.org/acme/new-reg” indicated an error: “Account creation on ACMEv1 is disabled. Please upgrade your ACME client to a version that supports ACMEv2 / RFC 8555. See End of Life Plan for ACMEv1 for details. (The client lacks sufficient authorization)” (403, “Forbidden”, urn:acme:error:unauthorized).
at /var/cpanel/perl/Cpanel/ACME/HTTP.pm line 134.
Cpanel::ACME::HTTP::ANON(Cpanel::Exception::HTTP::Server=HASH(0x2b13870)) called at /usr/local/cpanel/3rdparty/perl/528/lib/perl5/cpanel_lib/Try/Tiny.pm line 118
Try::Tiny::try(CODE(0x22ad3d8), Try::Tiny::Catch=REF(0x22ad510)) called at /var/cpanel/perl/Cpanel/ACME/HTTP.pm line 143
Cpanel::ACME::HTTP::_request(Cpanel::ACME::HTTP=HASH(0x2274670), “POST”, “https://acme-v01.api.letsencrypt.org/acme/new-reg”, HASH(0x2941bc8)) called at /var/cpanel/perl/Cpanel/ACME/HTTP.pm line 151
Cpanel::ACME::HTTP::_request_and_set_last_nonce(Cpanel::ACME::HTTP=HASH(0x2274670), “POST”, “https://acme-v01.api.letsencrypt.org/acme/new-reg”, HASH(0x2941bc8)) called at /var/cpanel/perl/Cpanel/ACME/HTTP.pm line 87
Cpanel::ACME::HTTP::post(Cpanel::ACME::HTTP=HASH(0x2274670), “https://acme-v01.api.letsencrypt.org/acme/new-reg”, HASH(0x228cda8)) called at /var/cpanel/perl/Cpanel/ACME.pm line 481
Cpanel::ACME::_post_url(Cpanel::ACME::LetsEncrypt=HASH(0x2274700), “https://acme-v01.api.letsencrypt.org/acme/new-reg”, HASH(0x228cda8)) called at /var/cpanel/perl/Cpanel/ACME.pm line 458
Cpanel::ACME::_post(Cpanel::ACME::LetsEncrypt=HASH(0x2274700), “new-reg”, HASH(0x228cda8)) called at /var/cpanel/perl/Cpanel/ACME.pm line 251
Cpanel::ACME::register(Cpanel::ACME::LetsEncrypt=HASH(0x2274700)) called at /var/cpanel/perl/Cpanel/SSL/Auto/Provider/LetsEncrypt.pm line 74
Cpanel::SSL::Auto::Provider::LetsEncrypt::PROPERTIES(“Cpanel::SSL::Auto::Provider::LetsEncrypt”) called at /usr/local/cpanel/Cpanel/SSL/Auto.pm line 81
Cpanel::SSL::Auto::ANON() called at /usr/local/cpanel/3rdparty/perl/528/lib/perl5/cpanel_lib/Try/Tiny.pm line 97
eval {…} called at /usr/local/cpanel/3rdparty/perl/528/lib/perl5/cpanel_lib/Try/Tiny.pm line 88
Try::Tiny::try(CODE(0x1d35130), Try::Tiny::Catch=REF(0xdc3d88)) called at /usr/local/cpanel/Cpanel/SSL/Auto.pm line 98
Cpanel::SSL::Auto::get_all_provider_info() called at whostmgr/bin/whostmgr12.pl line 620
main::autossl(“autossl”) called at /usr/local/cpanel/Whostmgr/Dispatch.pm line 259
Whostmgr::Dispatch::_do_call(“autossl”, HASH(0x1d0c1b8), HASH(0x1d0c4a0)) called at /usr/local/cpanel/Whostmgr/Dispatch.pm line 157
Whostmgr::Dispatch::dispatch(“autossl”, 1, ARRAY(0x1d0c218)) called at whostmgr/bin/whostmgr12.pl line 247
at /usr/local/cpanel/Cpanel/SSL/Auto.pm line 97.
Cpanel::SSL::Auto::ANON(Cpanel::Exception::ACME::Protocol=HASH(0x2b8f038)) called at /usr/local/cpanel/3rdparty/perl/528/lib/perl5/cpanel_lib/Try/Tiny.pm line 118
Let’s Encrypt is planning to shutdown ACME v1 completely and you should switch to ACME v2 soon.
Since you are using cPanel AutoSSL, it’s cPanel’s responsibility to upgrade to ACME v2 in their code.
This is a issue for cPanel / WHM, and they’ve already have a solution for this issue.
Please see the below link for a solution.
If this issue persists, please contact cPanel support directly.
Thank you
