Could not issue - failure to set certificate name
My domain is: skt.essence-design.co.uk
I ran this command: install on Plesk
It produced this output: failure to set certificate name
My web server is (include version): not sure sorry
The operating system my web server runs on is (include version): not sure
My hosting provider, if applicable, is: web hosting unlimited
I can login to a root shell on my machine (yes or no, or I don’t know): I don’t know
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk Onyx 17.5.3
You have apparently successfully generated some certificates: https://crt.sh/?q=skt.essence-design.co.uk
How did you generate them?
Did you use Plesk to generate a CSR ?
Did you try to follow that guide: https://www.unlimitedwebhosting.co.uk/client/knowledgebase/71/How-to-install-an-SSL-Cert-in-Plesk.html ?
Hi @sevenbe8
you have today created 4 certificates with the same name:
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=p:ZXNzZW5jZS1kZXNpZ24uY28udWs6ZmFsc2U6dHJ1ZTo6RUFFPQ&cert_search=include_expired:false;include_subdomains:true;domain:essence-design.co.uk&lu=cert_search_cert
Next certificate -> after that you will hit a limit. Why isn't it possible to use one of these certificates?
PS: crt.sh shows only certificates up to 2018-07-24
Thank you so much for looking at this. Sadly I am only technically capable of using the Plesk plugin for lets encrypt and hit the go button - that’s when it usually works but with this domain doesn’t.
Then it shows as not secure in Wordpress despite using the usual ssl plugin to redirect. Any ideas? I can upload it manually if I know how to download it perhaps?
Thank you
If you use such an integrated solution, your webhoster should have a solution.
There is an old, self signed certificate.
But from outside, it's unclear, where there may be an error.
