erp.dental.mpgi.net
erp.mpce.mpgi.net
I have tried “Re-issue” certificate option from plesk but getting the error.
Could not issue an SSL/TLS certificate for erp.dental.mpgi.net
Details
Could not issue a Let’s Encrypt SSL/TLS certificate for erp.dental.mpgi.net . Authorization for the domain failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz-v3/6876559596.
Details:
Type: urn:ietf:params:acme:error:connection
Status: 400
Detail: Fetching https://acme-challenge.localhost/.well-known/acme-challenge/KYTMmw1kNA1Emwq58L9Stnb3nxte_oObymLDwnw68yI: Invalid hostname in redirect target, must end in IANA registered TLD
Windows Server 2012
I don’t know
Yes, I am using plesk to manage the sites.
Hi @aamir.khan099
your redirect is wrong, see your check, ~~30 minutes old - erp.dental.mpgi.net - Make your website better - DNS, redirects, mixed content, certificates
• http://erp.dental.mpgi.net/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 131.153.76.58 Inline-JavaScript (∑/total): 0/0 Inline-CSS (∑/total): 0/0 302 https://acme-challenge.localhost/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
Html is minified: 102,82 % 0.404
E
Visible Content: Object moved to here .
• http://www.erp.dental.mpgi.net/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 131.153.76.58 Inline-JavaScript (∑/total): 0/0 Inline-CSS (∑/total): 0/0 302 https://acme-challenge.localhost/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
Html is minified: 102,82 % 0.390
E
http + /.well-known/acme-challenge/random-filename is redirected to the not global defined domain name acme-challenge.localhost.
Find that redirect and change it.
Looks like you have an additional subdomain as target. That's possible, but the complete domain name is required.
Hi JuergenAuer,
Thanks for the reply. As you suggested below, i understand its wrong - but the same is working for other sub-domain on mpgi.net, the only issue is with erp.dental.mpgi.net and erp.mpce.mpgi.net :
http + /.well-known/acme-challenge/random-filename is redirected to the not global defined domain name acme-challenge.localhost .
They all are hosted on the same server, could you please suggest “Find that redirect and change it.” - where should i find this, as far as I am aware, there is a website on IIS with the name “acme-challenge” which pointing to http binding to acme-challenge.localhost
Could you please suggest something, so that it should affect the other application on the same server.
