Connection Refused when running certbot
I cannot get certbot to run through. Whenever I tried to issue a new certificate, i'll get a "connection refused" error upon all challenges.
My domain is: icechat.ch
sudo certbot certonly --standalone -d icechat.ch -d www.icechat.ch -d irc.icechat.ch
Requesting a certificate for icechat.ch and 2 more domains
http-01 challenge for icechat.ch
http-01 challenge for irc.icechat.ch
http-01 challenge for www.icechat.ch
Challenge failed for domain icechat.ch
Challenge failed for domain irc.icechat.ch
Challenge failed for domain www.icechat.ch
   Domain: icechat.ch
   Type:   connection
   Detail: Fetching
   http://icechat.ch/.well-known/acme-challenge/hT2oAFuuriJpRK-_HUfRW3ymvVHQa1Tz1FSDASDEL8w:
   Connection refused
   Domain: irc.icechat.ch
   Type:   connection
   Detail: Fetching
   http://irc.icechat.ch/.well-known/acme-challenge/4g1Xt4kuRDPnAFei_vdwV_tEeYR71tnt8_4rPHBoMVI:
   Connection refused
   Domain: www.icechat.ch
   Type:   connection
   Detail: Fetching
   http://www.icechat.ch/.well-known/acme-challenge/CN8UZ8eMMBy0cxdzqhu8SjdvjJvj0M_STvWG6KhcJmk:
   Connection refused
My web server is (include version): tomcat 9.0.41
The operating system my web server runs on is (include version): Debian 10
My hosting provider, if applicable, is: hetzner.com
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.11.0
Server is stopped, and ports are open. ufw status output:
sudo ufw status
Status: active
To                         Action      From
22/tcp                     ALLOW       Anywhere
22                         ALLOW       Anywhere
6667                       ALLOW       Anywhere
6697                       ALLOW       Anywhere
8843                       ALLOW       Anywhere
8000                       ALLOW       Anywhere
WWW                        ALLOW       Anywhere
8080                       ALLOW       Anywhere
8443                       ALLOW       Anywhere
80                         ALLOW       Anywhere
80/tcp                     ALLOW       Anywhere
443/tcp                    ALLOW       Anywhere
80,443/tcp                 ALLOW       Anywhere
22/tcp (v6)                ALLOW       Anywhere (v6)
22 (v6)                    ALLOW       Anywhere (v6)
6667 (v6)                  ALLOW       Anywhere (v6)
6697 (v6)                  ALLOW       Anywhere (v6)
8843 (v6)                  ALLOW       Anywhere (v6)
8000 (v6)                  ALLOW       Anywhere (v6)
WWW (v6)                   ALLOW       Anywhere (v6)
8080 (v6)                  ALLOW       Anywhere (v6)
8443 (v6)                  ALLOW       Anywhere (v6)
80/tcp (v6)                ALLOW       Anywhere (v6)
443/tcp (v6)               ALLOW       Anywhere (v6)
80,443/tcp (v6)            ALLOW       Anywhere (v6)
The domain is pointing to the correct IP address and other server using the same provider produced no issues.
What else can I check to get my certificate? :slight_smile:
Thanks for any pointers.
iptables --list
sudo iptables --list
Chain INPUT (policy DROP)
target     prot opt source               destination
ufw-before-logging-input  all  --  anywhere             anywhere
ufw-before-input  all  --  anywhere             anywhere
ufw-after-input  all  --  anywhere             anywhere
ufw-after-logging-input  all  --  anywhere             anywhere
ufw-reject-input  all  --  anywhere             anywhere
ufw-track-input  all  --  anywhere             anywhere
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:http
Chain FORWARD (policy DROP)
ufw-before-logging-forward  all  --  anywhere             anywhere
ufw-before-forward  all  --  anywhere             anywhere
ufw-after-forward  all  --  anywhere             anywhere
ufw-after-logging-forward  all  --  anywhere             anywhere
ufw-reject-forward  all  --  anywhere             anywhere
ufw-track-forward  all  --  anywhere             anywhere
Chain OUTPUT (policy ACCEPT)
ufw-before-logging-output  all  --  anywhere             anywhere
ufw-before-output  all  --  anywhere             anywhere
ufw-after-output  all  --  anywhere             anywhere
ufw-after-logging-output  all  --  anywhere             anywhere
ufw-reject-output  all  --  anywhere             anywhere
ufw-track-output  all  --  anywhere             anywhere
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-input (1 references)
ACCEPT     all  --  anywhere             anywhere
ACCEPT     all  --  anywhere             anywhere             ctstate RELATED,ESTABLISHED
ufw-logging-deny  all  --  anywhere             anywhere             ctstate INVALID
DROP       all  --  anywhere             anywhere             ctstate INVALID
ACCEPT     icmp --  anywhere             anywhere             icmp destination-unreachable
ACCEPT     icmp --  anywhere             anywhere             icmp time-exceeded
ACCEPT     icmp --  anywhere             anywhere             icmp parameter-problem
ACCEPT     icmp --  anywhere             anywhere             icmp echo-request
ACCEPT     udp  --  anywhere             anywhere             udp spt:bootps dpt:bootpc
ufw-not-local  all  --  anywhere             anywhere
ACCEPT     udp  --  anywhere             224.0.0.251          udp dpt:mdns
ACCEPT     udp  --  anywhere             239.255.255.250      udp dpt:1900
ufw-user-input  all  --  anywhere             anywhere
Chain ufw-before-output (1 references)
ufw-user-output  all  --  anywhere             anywhere
Chain ufw-before-forward (1 references)
ufw-user-forward  all  --  anywhere             anywhere
Chain ufw-after-input (1 references)
ufw-skip-to-policy-input  udp  --  anywhere             anywhere             udp dpt:netbios-ns
ufw-skip-to-policy-input  udp  --  anywhere             anywhere             udp dpt:netbios-dgm
ufw-skip-to-policy-input  tcp  --  anywhere             anywhere             tcp dpt:netbios-ssn
ufw-skip-to-policy-input  tcp  --  anywhere             anywhere             tcp dpt:microsoft-ds
ufw-skip-to-policy-input  udp  --  anywhere             anywhere             udp dpt:bootps
ufw-skip-to-policy-input  udp  --  anywhere             anywhere             udp dpt:bootpc
ufw-skip-to-policy-input  all  --  anywhere             anywhere             ADDRTYPE match dst-type BROADCAST
Chain ufw-after-output (1 references)
Chain ufw-after-forward (1 references)
Chain ufw-after-logging-input (1 references)
LOG        all  --  anywhere             anywhere             limit: avg 3/min burst 10 LOG level warning prefix "[UFW BLOCK] "
Chain ufw-after-logging-output (1 references)
Chain ufw-after-logging-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-reject-forward (1 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
ACCEPT     tcp  --  anywhere             anywhere             ctstate NEW
ACCEPT     udp  --  anywhere             anywhere             ctstate NEW
Chain ufw-track-forward (1 references)
Chain ufw-logging-deny (2 references)
RETURN     all  --  anywhere             anywhere             ctstate INVALID limit: avg 3/min burst 10
Chain ufw-logging-allow (0 references)
LOG        all  --  anywhere             anywhere             limit: avg 3/min burst 10 LOG level warning prefix "[UFW ALLOW] "
Chain ufw-skip-to-policy-input (7 references)
Chain ufw-skip-to-policy-output (0 references)
Chain ufw-skip-to-policy-forward (0 references)
Chain ufw-not-local (1 references)
RETURN     all  --  anywhere             anywhere             ADDRTYPE match dst-type LOCAL
RETURN     all  --  anywhere             anywhere             ADDRTYPE match dst-type MULTICAST
RETURN     all  --  anywhere             anywhere             ADDRTYPE match dst-type BROADCAST
ufw-logging-deny  all  --  anywhere             anywhere             limit: avg 3/min burst 10
Chain ufw-user-input (1 references)
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:ssh
ACCEPT     udp  --  anywhere             anywhere             udp dpt:22
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:ircd
ACCEPT     udp  --  anywhere             anywhere             udp dpt:6667
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:ircs-u
ACCEPT     udp  --  anywhere             anywhere             udp dpt:6697
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:8843
ACCEPT     udp  --  anywhere             anywhere             udp dpt:8843
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:8000
ACCEPT     udp  --  anywhere             anywhere             udp dpt:8000
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:http /* 'dapp_WWW' */
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:http-alt
ACCEPT     udp  --  anywhere             anywhere             udp dpt:http-alt
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:8443
ACCEPT     udp  --  anywhere             anywhere             udp dpt:8443
ACCEPT     tcp  --  anywhere             anywhere             tcp dpt:https
ACCEPT     tcp  --  anywhere             anywhere             multiport dports http,https
Chain ufw-user-output (1 references)
Chain ufw-user-forward (1 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-limit (0 references)
LOG        all  --  anywhere             anywhere             limit: avg 3/min burst 5 LOG level warning prefix "[UFW LIMIT BLOCK] "
REJECT     all  --  anywhere             anywhere             reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
Try running:
tcpdump port 80
And see if you actually get any http packets.
If not, your ISP may be blocking port 80.
Hi @fish-guts
--standalone is hard to debug, there is no running webserver.
But
http://icechat.ch/
doesn't answer, instead, there is a blocking answer (firewall, htaccess, failban etc.).
So create and start a webserver, then you can use online tools to test your configuration. If online tools can't connect your website, Letsencrypt can't check your domain name via http validation.
Hi JuergenAuer
I switched off the webserver before running certbot
If Tomcat is running, the site is available, on all configured ports. tcpdump port 80 show the following output:
sudo tcpdump port 80
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
07:38:39.308326 IP ***.37028 > ***.http: Flags [S], seq 3342630620, win 64240, options [mss 1440,sackOK,TS val 2479407215 ecr 0,nop,wscale 7], length 0
07:38:39.308456 IP ***.http > ***.37028: Flags [R.], seq 0, ack 3342630621, win 0, length 0
07:38:39.628536 IP ***.37030 > ***r.de.http: Flags [S], seq 247779336, win 64240, options [mss 1440,sackOK,TS val 2479407536 ecr 0,nop,wscale 7], length 0
This is good news - your ISP is NOT blocking port 80 (that would have been an insurmountable problem).
But it is still strange why this fails...
Please show:
netstat -pant | grep -i listen
[while TOMCAT is running]
tcp        0      0 0.0.0.0:6697            0.0.0.0:*               LISTEN      20343/unrealircd
tcp        0      0 0.0.0.0:6667            0.0.0.0:*               LISTEN      20343/unrealircd
tcp        0      0 0.0.0.0:6900            0.0.0.0:*               LISTEN      20343/unrealircd
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      707/sshd
tcp6       0      0 :::6697                 :::*                    LISTEN      20343/unrealircd
tcp6       0      0 :::6667                 :::*                    LISTEN      20343/unrealircd
tcp6       0      0 :::8080                 :::*                    LISTEN      31441/java
tcp6       0      0 :::6900                 :::*                    LISTEN      20343/unrealircd
tcp6       0      0 :::22                   :::*                    LISTEN      707/sshd
Now http://icechat.ch/ works, same with http://icechat.ch/.well-known/acme-challenge/1234.
If possible, use the correct webroot of that Tomcat, not --standalone.
Unfortunaely, it's still not working:
sudo certbot certonly --webroot -d icechat.ch -d www.icechat.ch
Requesting a certificate for icechat.ch and www.icechat.ch
Input the webroot for icechat.ch: (Enter 'c' to cancel): /opt/tomcat/webapps
Select the webroot for www.icechat.ch:
1: Enter a new webroot
2: /opt/tomcat/webapps
   Domain: icechat.ch
   Type:   unauthorized
   Detail: Invalid response from
   http://icechat.ch/.well-known/acme-challenge/NUUj2A8_TReNpiIzR0GZUXL2T1u5eADq4A9Y6wRrwAE
   [88.99.190.217]: "<!doctype html><html
   lang=\"en\"><head><title>HTTP Status 404 – Not Found</title><style
   type=\"text/css\">body {font-family:Tahoma"
   Type:   unauthorized
   http://www.icechat.ch/.well-known/acme-challenge/gFAwbB0OwE_ng3AjGZbCjpUKPHIYq4z7fXzPR5t6YpU
Then you use the wrong webroot. Change that.
Thanks, that did the trick (I wasn't aware that the ROOT directory needs to be specified as well).
Now I successfully created a certificate. I appreciate the help :slight_smile:
I'm glad to hear that you were able to get the cert :slight_smile:
It seems that port 80 connects to TOMCAT on port 8080.
I don't know where that translation is happening, but it must be; as the netstat did not show port 80 listening locally and TOMCAT is answering to it from the Internet.
