Connection refused when requesting new cerfificate via script - possible hangover of previous redirects?
Back in February I ran the shell script pasted below to generate a letsencrypt certificate on my server. It worked, and after I had it I set up a docker-compose file with services nginx, certbot, among others, to redirect http://example.com to https://example.com. All was well for 90 days till renewal time. My automated renewal failed. I guess for the same reason my attempt to manually get a new certificate via the init shell file below also fails this time around.
The docker services that handled the redirects from http to https have been stopped yet the redirects appear to remain in place. There's currently no reverse proxy running since I have stopped the nginx container. However visiting http://collabora.alamko.de STILL tries to redirect to https. I suspect this is part of or related to my issue. The browser tells me 'connection refused', the same as the output message below 'Certbot failed'.
It looks like the script which obtains the certificate try's a url at http but this time around it's being redirected to https which is perhaps what's causing the problem? See the output below.
collabora.alamko.de
See pasted shell script below init-letsencrypt.sh
  Domain: collabora.alamko.de
  Type:   connection
  Detail: Fetching http://collabora.alamko.de/.well-known/acme-challenge/f7ANvS1aFRNrx5BN7gbeEDGiF5cG3xCLWI-RVm7AOT0: Connection refused
Looking at the sh script mentioned above, init-letsencrypt.sh, it seems to be using nginx via a docker container.
Ubuntu 20.04.1 LTS
Hetzner
Yes
No.
Certbot via docker. I presume latest'? Details in the init sh script below.
Here is the init-letsencrypt.sh that I've been referencing throughout my post (Not my script, downloaded from a blog out there somewhere). Before, when I ran this script the outcome was a newly generated letsencrypt certificate. This time around I get the 'connection refused' error message:
#!/bin/bash
if ! [ -x "$(command -v docker-compose)" ]; then
  echo 'Error: docker-compose is not installed.' >&2
  exit 1
fi
domains=(collabora.alamko.de)
rsa_key_size=4096
data_path="./data/certbot"
email="myemail@fastmail.com" # Adding a valid address is strongly recommended
staging=0 # Set to 1 if you're testing your setup to avoid hitting request limits
if [ -d "$data_path" ]; then
  read -p "Existing data found for $domains. Continue and replace existing certificate? (y/N) " decision
  if [ "$decision" != "Y" ] && [ "$decision" != "y" ]; then
    exit
  fi
fi
if [ ! -e "$data_path/conf/options-ssl-nginx.conf" ] || [ ! -e "$data_path/conf/ssl-dhparams.pem" ]; then
  echo "### Downloading recommended TLS parameters ..."
  mkdir -p "$data_path/conf"
  curl -s https://raw.githubusercontent.com/certbot/certbot/master/certbot-nginx/certbot_nginx/_internal/tls_configs/options-ssl-nginx.conf > "$data_path/conf/options-ssl-nginx.conf"
  curl -s https://raw.githubusercontent.com/certbot/certbot/master/certbot/certbot/ssl-dhparams.pem > "$data_path/conf/ssl-dhparams.pem"
  echo
fi
echo "### Creating dummy certificate for $domains ..."
path="/etc/letsencrypt/live/$domains"
mkdir -p "$data_path/conf/live/$domains"
docker-compose run --rm --entrypoint "\
  openssl req -x509 -nodes -newkey rsa:$rsa_key_size -days 1\
    -keyout '$path/privkey.pem' \
    -out '$path/fullchain.pem' \
    -subj '/CN=localhost'" certbot
echo
echo "### Starting nginx ..."
docker-compose up --force-recreate -d nginx
echo
echo "### Deleting dummy certificate for $domains ..."
  rm -Rf /etc/letsencrypt/live/$domains && \
  rm -Rf /etc/letsencrypt/archive/$domains && \
  rm -Rf /etc/letsencrypt/renewal/$domains.conf" certbot
echo
echo "### Requesting Let's Encrypt certificate for $domains ..."
#Join $domains to -d args
domain_args=""
for domain in "${domains[@]}"; do
  domain_args="$domain_args -d $domain"
done
# Select appropriate email arg
case "$email" in
  "") email_arg="--register-unsafely-without-email" ;;
  *) email_arg="--email $email" ;;
esac
# Enable staging mode if needed
if [ $staging != "0" ]; then staging_arg="--staging"; fi
  certbot certonly --webroot -w /var/www/certbot \
    $staging_arg \
    $email_arg \
    $domain_args \
    --rsa-key-size $rsa_key_size \
    --agree-tos \
    --force-renewal" certbot
echo
echo "### Reloading nginx ..."
docker-compose exec nginx nginx -s reload
Given my server seems to continue to redirect, even though I've switched off the docker services that created and managed the redirects, how can I obtain a new letsencrypt certificate?
hi @dougfir and welcome to the LE community forum :slight_smile:
When using --webroot, the -w path provided must match the document root (found in the vhost config) for the expected challenge location (http://your.domain/.well-known/acme-challenge/).
And... who wrote the script?:
Hi @rg305 thanks for the welcome!
And who wrote the script
I found the script on this repo.
When using --webroot , the -w path provided must match the document root (found in the vhost config) for the expected challenge location ( http://your.domain/.well-known/acme-challenge/ ).
OK. This is new terminology to me. I'm unsure what to do with this information or how to action your feedback?! Vhost config... is that something that would exist on my server or is it directly related to the script I shared? Requesting a little hand holding here if you will...
That script should be removed from the internet in total. It contains stuff which can lead to hitting rate limits if one does not understand the purpose of the script.
Further more, I assumes a working nginx docker container and it also assumes the document root of the site is /var/www/certbot for some reason. Which is a little bit odd, unless the nginx container is specifically configured to work.
So, a few follow-up questions:
  • Where did you find this script?
  • Is your nginx container custom build by yourself or did you fetched some kind of "pre-build" nginx container and if so, where from?
Hi @Osiris. Thanks for your feedback. Your questions:
The repo where I got the script is here. The script in question is in the root of the repo
I copied what they have on the repo for the nginx container. Here's my docker-compose in case it's useful:
version: "3.5"
networks:
  collabora:
volumes:
  shared_run:
services:
  collabora:
    image: collabora/code
    container_name: collabora
    restart: always
    cap_add:
      - MKNOD
    environment:
      - "extra_params=--o:ssl.enable=false --o:ssl.termination=true"
      - domain=${NEXTCLOUD_DOMAIN}
      - dictionaries=en_US
    ports:
      - "9980:9980"
    volumes:
      - ./appdata/collabora:/config
    networks:
      - collabora
  nginx:
    image: nginx:1.19
    volumes:
      - "shared_run:/run"
      - ./data/nginx/templates:/etc/nginx/templates
      - ./data/certbot/conf:/etc/letsencrypt
      - ./data/certbot/www:/var/www/certbot
      - ./reload.sh:/docker-entrypoint.d/reload.sh
    ports:
      - "80:80"
      - "443:443"
    env_file: .env
    networks:
      - collabora
  certbot:
    image: certbot/certbot
    restart: unless-stopped
    volumes:
    entrypoint: "/bin/sh -c 'trap exit TERM; while :; do certbot renew; sleep 12h & wait $${!}; done;'"
    networks:
      - collabora
Please let me know if there's any more info I can provide?
Perhaps a dump of the nginx config would be helpful too.
nginx -T
Thanks for the pointer. Here's the output of nginx -T from within the nginx container:
nginx -T
2021/06/03 17:49:58 [emerg] 746#746: host not found in upstream "collabora" in /etc/nginx/conf.d/app.conf:30
nginx: [emerg] host not found in upstream "collabora" in /etc/nginx/conf.d/app.conf:30
nginx: configuration file /etc/nginx/nginx.conf test failed
Here is the content of /etc/nginx/conf.d/app.conf in case it's useful info:
cat /etc/nginx/conf.d/app.conf
ssl_certificate		/etc/letsencrypt/live/collabora.alamko.de/fullchain.pem;
ssl_certificate_key	/etc/letsencrypt/live/collabora.alamko.de/privkey.pem;
	listen			80;
	server_name		www.collabora.alamko.de collabora.alamko.de;
		root /var/www/certbot;
	return 301 https://collabora.alamko.de$request_uri;
	listen			443 ssl;
	server_name		www.collabora.alamko.de;
	return 301 $scheme://collabora.alamko.de$request_uri;
	listen			443 ssl;
	server_name		collabora.alamko.de;
		proxy_pass http://collabora:9980;
		access_log off;
		proxy_set_header Host $host;
	# static files
	location ^~ /loleaflet {
		proxy_set_header Host $http_host;
	# WOPI discovery URL
		location ^~ /hosting/discovery {
	# Capabilities
	location ^~ /hosting/capabilities {
	# main websocket
	location ~ ^/lool/(.*)/ws$ {
		proxy_set_header Connection "Upgrade";
		proxy_read_timeout 36000s;
	# download, presentation and image upload
	location ~ ^/lool {
	# Admin Console websocket
	location ^~ /lool/adminws {
And here's the nginx.conf file referenced in the message too:
cat /etc/nginx/nginx.conf
user  nginx;
worker_processes  1;
error_log  /var/log/nginx/error.log warn;
pid        /var/run/nginx.pid;
events {
    worker_connections  1024;
http {
    include       /etc/nginx/mime.types;
    default_type  application/octet-stream;
    log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                      '$status $body_bytes_sent "$http_referer" '
                      '"$http_user_agent" "$http_x_forwarded_for"';
    access_log  /var/log/nginx/access.log  main;
    sendfile        on;
    #tcp_nopush     on;
    keepalive_timeout  65;
    #gzip  on;
This explains why they used /var/www/certbot :
Try instead:
sudo nginx -T
or also show:
ls -l /etc/nginx/conf.d/*.conf
Here is the output of both suggestions:
sudo nginx -T
bash: sudo: command not found
root@123:/# ls -l /etc/nginx/conf.d/*.conf
-rw-r--r-- 1 root root 1729 Jun  3 12:03 /etc/nginx/conf.d/app.conf
-rw-r--r-- 1 root root 1114 Jun  3 12:03 /etc/nginx/conf.d/default.conf
I think because I'm in a container there's limited utilities, in this case no sudo
Well you showed app.conf.
Let's also see the default.conf file.
[I still don't see where the certificate files are being used]
Nginx doesn't understand what is meant with the hostname collabora in the proxy_pass directives in your configuration. That's why it won't start and that's why a "connection refused" is reported by the LE validation server: there's no webserver running to connect to.
Please fix your proxy_pass directives to use a hostname which nginx can understand and try again.
Also please note that once you've managed to get a certificate issued, DO NOT USE the init-letsencrypt.sh script again, as it will delete perfectly fine certificates if you run it.. If something is not working after you've managed to succesfully get a certificate, you need to figure it out without running the script again.
I'm guessing using ssl in listen 443 ssl; from within a server {} block will work, even if ssl_certificate and ssl_certificate_key are located outside any block at all.
And also please show the output of:
certbot certificates
Might be something like:
docker-compose run --rm --entrypoint "certbot certificates" certbot
Hi, I updated the proxy_pass directives but I got the same error message:
nginx -T
2021/06/03 18:43:52 [emerg] 80#80: host not found in upstream "collabora" in /etc/nginx/conf.d/oldapp.conf:30
nginx: [emerg] host not found in upstream "collabora" in /etc/nginx/conf.d/oldapp.conf:30
Here's how the conf file looks now with this update:
	listen			80;
	listen			443 ssl;
	listen			443 ssl;
		proxy_pass http://collabora.alamko.de:9980;
		access_log off;
	# static files
	# Capabilities
	# main websocket
	location ~ ^/lool {
Hi, I ran your suggested line of code:
Creating collabora_certbot_run ... done
No certificates found.
:confused:
Did you update the correct file, i.e., the app.conf used inside the docker container?
I see the docker-compose.yml file from the github repository containing the script you're using has the following at the nginx volume section:
  - ./data/nginx:/etc/nginx/conf.d
This is missing from your docker compose file it seems? So, where does the nginx container get its app.conf from and did you indeed edit the correct one?
Here's the default.conf:
But note, since I'm using a version of nginx that uses global variables sourced from .env file I use event substitution which in the nginx image I'm using, now seems to support this out of the box. See answer from Martin further down. i.e. It's the app.conf file that is generated.
cat /etc/nginx/conf.d/default.conf
    listen       80;
    listen  [::]:80;
    server_name  localhost;
    #charset koi8-r;
    #access_log  /var/log/nginx/host.access.log  main;
        root   /usr/share/nginx/html;
        index  index.html index.htm;
    #error_page  404              /404.html;
    # redirect server error pages to the static page /50x.html
    error_page   500 502 503 504  /50x.html;
    location = /50x.html {
    # proxy the PHP scripts to Apache listening on 127.0.0.1:80
    #location ~ \.php$ {
    #    proxy_pass   http://127.0.0.1;
    # pass the PHP scripts to FastCGI server listening on 127.0.0.1:9000
    #    root           html;
    #    fastcgi_pass   127.0.0.1:9000;
    #    fastcgi_index  index.php;
    #    fastcgi_param  SCRIPT_FILENAME  /scripts$fastcgi_script_name;
    #    include        fastcgi_params;
    # concurs with nginx's one
    #location ~ /\.ht {
    #    deny  all;
Yep, here's some bash output from while inside the nginx container:
-rw-r--r-- 1 root root 1799 Jun  3 18:31 /etc/nginx/conf.d/app.conf
-rw-r--r-- 1 root root 1114 Jun  3 18:31 /etc/nginx/conf.d/default.conf
-rw-r--r-- 1 root root 1729 Jun  3 18:31 /etc/nginx/conf.d/oldapp.conf
root@3bf8b15abb47:/# cat /etc/nginx/conf.d/app.conf
	listen			80;
	listen			443 ssl;
	listen			443 ssl;
		access_log off;
	# static files
	# Capabilities
	# main websocket
	location ~ ^/lool {
I think the default.conf comes out of the box. I wonder if I somehow need to remove that one or if nginx is confused by which one to use.
I use variable substitution to read vars from .env which nginx now seems to support. See Martins answer further down here. This generates the app.conf file.
Then I don't understand what's nginx -T still complaining about...
Do you think it's possible nginx is confused by the existence of 2 conf files app.conf and default.conf. I want nginx to use app.conf, I don't know how default.conf get's there presumably it's part of the image :confused:
New info, my 'oldapp.conf' file which I'd left in the same dir seemed to be causing issues. New error message after doing some housekeeping:
nginx -T
2021/06/03 19:07:34 [emerg] 58#58: cannot load certificate "/etc/letsencrypt/live/collabora.alamko.de/fullchain.pem": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/collabora.alamko.de/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
nginx: [emerg] cannot load certificate "/etc/letsencrypt/live/collabora.alamko.de/fullchain.pem": BIO_new_file() failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/collabora.alamko.de/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
