timbrc
September 17, 2019, 4:22pm
#1
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: timdcs.com
My web server is (include version): microsoft windows server 2016
The operating system my web server runs on is (include version): microsoft windows server 2016
My hosting provider, if applicable, is: godaddy
I can login to a root shell on my machine (yes or no, or I don’t know): i dont know
or certbot-auto --version
if you’re using Certbot):
Hi @timbrc
checking your domain there is only the standard Ookla certificate visible (older check, ~~ two hours old - https://check-your-website.server-daten.de/?q=timdcs.com ):
CN=server-27443.prod.hosts.ooklaserver.net (19574)
10.09.2019
09.12.2019
expires in 83 days
103.219.70.170.prod.hosts.ooklaserver.net, server-27443.prod.hosts.ooklaserver.net - 2 entries
You have to create an own certificate.
But there is no older certificate, so it's your first certificate.
Start with some basics:
Then select a client to create a certificate:
Last updated: Nov 24, 2021 | See all Documentation Let’s Encrypt uses the ACME protocol to verify that you control a given domain name and to issue you a certificate. To get a Let’s Encrypt certificate, you’ll need to choose a piece...
timbrc
September 19, 2019, 3:18pm
#3
Hi Sir, appreciate your feedback in my inquiry, I will give it a go and see what will happen.
Thank you so much.
system
closed
October 19, 2019, 3:25pm
#4
