Hello,
I’ve been trying to set up an SSL certificate for my website with Certbot but for some reason I keep getting prompted to the connection not secured screen before accessing the site and there’s a little warning icon at the url address that indicates it as well.
I ran certbot-auto --apache and was prompted to enter my domain, so I used imperium-roleplay.tk and www.imperium-roleplay.tk
It seems to have worked(eventually I got a Congratulations message) and I can see the certs in certbot-auto certificates.
This is what I get by testing the SSL via whynopadlocks: Self Signed Certificate
Your SSL certificate appears to be self signed.
Browsers will display an error whenever someone attempts to visit your site.
Domain Matching
Your SSL certificate does not match your domain name! Protected Domains:
No Domains Listed
I’m a real noob when it comes to certificates so I’d love some help
(I’m using CentOS 6)
@JuergenAuer
Do you mean a reboot or are you talking about restarting the apache service(I restarted the apache, not the whole server).
Sorry for the noobish question but by pre- you refer to the www. prefix?
I assume I needed to create 1 for each? Thing is when I used certbot-auto certificates it seems like there was only one, I probably messed something up when I tried fixing it…
@JuergenAuer Assuming I delete the 2nd certificate, will the problem be fixed? Because when I try accessing the site via https://imperium-roleplay.tk it still shows as if it’s not secure.
How do I delete the cert?
Edit: I deleted the cert but on that site you provided me with it seems like there are still 4 certs…
Here’s the output of certbot-auto certificates:
[root@vps625821 ~]# ./certbot-auto certificates
Found the following certs:
Certificate Name: imperium-roleplay.tk
Domains: imperium-roleplay.tk www.imperium-roleplay.tk
Expiry Date: 2019-03-13 17:54:00+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/imperium-roleplay.tk/fullchain.pem
Private Key Path: /etc/letsencrypt/live/imperium-roleplay.tk/privkey.pem
and I tried deleting all of my certificates and installing new ones by using certbox-auto delete and for some reason when I try to create new ones I get this error:
Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.
I’m so confused right now
EDIT:
Got this output when I used apachectl -t -D DUMP_VHOSTS
VirtualHost configuration:
wildcard NameVirtualHosts and default servers:
*:443 is a NameVirtualHost
default server www.imperium-roleplay.tk (/etc/httpd/conf.d/ssl.conf:74)
port 443 namevhost www.imperium-roleplay.tk (/etc/httpd/conf.d/ssl.conf:74)
Syntax OK
Thank you.
I managed to install the certificates back but the website still shows as if they’re unsecure(There are only 2 certificates now, as there should)…
What could be the problem? What am I missing here?
What I think is happening is that there is probably a duplication of HTTPS VirtualHosts for www.imperium-roleplay.tk (one in ssl.conf, and one in a file that Certbot creates).
@_az
This is the output:
*:80 imperium-roleplay.tk (/etc/httpd/conf.d/default.conf:1)
Syntax OK
Binary file /etc/httpd/modules/mod_ssl.so matches
/etc/httpd/conf.d/ssl.conf:# Point SSLCertificateFile at a PEM encoded certificate. If
/etc/httpd/conf.d/ssl.conf:SSLCertificateFile /etc/pki/tls/certs/localhost.crt
/etc/httpd/conf.d/ssl.conf:SSLCertificateKeyFile /etc/pki/tls/private/localhost.key
/etc/httpd/conf.d/ssl.conf:# the referenced file can be the same as SSLCertificateFile
/etc/httpd/conf.d/ssl.conf.1:# Point SSLCertificateFile at a PEM encoded certificate. If
/etc/httpd/conf.d/ssl.conf.1:SSLCertificateFile /etc/pki/tls/certs/localhost.crt
/etc/httpd/conf.d/ssl.conf.1:SSLCertificateKeyFile /etc/pki/tls/private/localhost.key
/etc/httpd/conf.d/ssl.conf.1:# the referenced file can be the same as SSLCertificateFile
/etc/httpd/conf.d/default-le-ssl.conf:SSLCertificateFile /etc/letsencrypt/live/imperium-roleplay.tk/cert.pem
/etc/httpd/conf.d/default-le-ssl.conf:SSLCertificateKeyFile /etc/letsencrypt/live/imperium-roleplay.tk/privkey.pem
I’m not sure what to make of it. Maybe it’s all weird because you’re running on an old version of Apache (2.2) ? Maybe @bmw can advise on what’s happening?
Problem is not with the auto renew. It’s that the website displays as not secure and also prompts for Chrome’s bad idea page before accessing the site.
