Connection error when creating certificate
My domain is:oiltest24.de
I ran this command:sudo certbot --apache -d oiltest24.de -d www.oiltest24.de
Failed authorization procedure. www.oiltest24.de (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.oiltest24.de/.well-known/acme-challenge/t-s0PqHOCypSpJnAR-slhhwZug1RTmYKDy1S8gTNN9Y: Timeout during connect (likely firewall problem)
My web server is (include version):apache2 Version 2.4.29
The operating system my web server runs on is (include version):Ubuntu 18.04
My hosting provider, if applicable, is:unknown
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):0.31.0
You've got two IP addresses configured for your domain (same goes for the www subdomain):
oiltest24.de.		86400	IN	A	89.22.111.88
oiltest24.de.		86400	IN	A	89.22.115.142
For the IP address 89.22.111.88 I can connect to port 80 without a problem, but I can't connect to 89.22.115.142 on port 80.
There's a 50 % chance Let's Encrypt will choose either one of those IP addresses per validation attempt and there are a multiple of validation attempts (also a few from secondary locations). So there's a pretty good chance the whole validation will fail.
Also, I don't know of both IP addresses are on the same server? Because even if you do manage to open up port 80 for 89.22.115.142, if that's a different server than the server you're running certbot on, the challenge will fail too.
Hi, you are right I honestly dont know why there is a second A record with the 89.22.115.142 IP, it shouldnt be there. I will have a look into the A records and try again. Thank you.
