Connect ETIMEDOUT, stack=Error: connect ETIMEDOUT
My domain is: cloud.itwindow.co.za
I ran this command: ./proxcp-deamon (docker image command)
https://hub.docker.com/r/proxcp/proxcp-daemon-v17-nodev12
2023-11-23T10:19:22.853Z - info: [PROXCP] Getting SSL certificate from Let's Encrypt - please wait...
ACME Directory URL: https://acme-v02.api.letsencrypt.org/directory
2023-11-23T10:21:40.002Z - info: message=connect ETIMEDOUT 41.161.86.3:80, stack=Error: connect ETIMEDOUT 41.161.86.3:80
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16), errno=ETIMEDOUT, code=ETIMEDOUT, syscall=connect, address=41.161.86.3, port=80, context=cert_issue, subject=cloud.itwindow.co.za, altnames=[cloud.itwindow.co.za, www.cloud.itwindow.co.za]
2023-11-23T10:21:40.003Z - info: message=connect ETIMEDOUT 41.161.86.3:80, stack=Error: connect ETIMEDOUT 41.161.86.3:80
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1144:16), errno=ETIMEDOUT, code=ETIMEDOUT, syscall=connect, address=41.161.86.3, port=80, context=cert_issue, subject=cloud.itwindow.co.za, altnames=[cloud.itwindow.co.za, www.cloud.itwindow.co.za], toJSON=function errorToJSON(e) {
var error = {};
Object.getOwnPropertyNames(e).forEach(function(k) {
error[k] = e[k];
return error;
}, servername=cloud.itwindow.co.za, subject=cloud.itwindow.co.za, $ref=$["altnames"], renewAt=1, module=acme-http-01-webroot, webroot=/var/www/html/.well-known/acme-challenge
2023-11-23T10:21:40.004Z - info: message=connect ETIMEDOUT 41.161.86.3:80, stack=Error: connect ETIMEDOUT 41.161.86.3:80
var error = {};
error[k] = e[k];
return error;
2023-11-23T10:21:40.005Z - info: message=connect ETIMEDOUT 41.161.86.3:80, stack=Error: connect ETIMEDOUT 41.161.86.3:80
var error = {};
error[k] = e[k];
return error;
My web server is (include version): apache
The operating system my web server runs on is (include version): ubuntu 23
I have no experience with that ACME client but it looks to be using an HTTP Challenge to get the cert.
The error message is not from Let's Encrypt but there is clearly a comms problem to or from your container. Right now I cannot reach your domain using HTTP which is required for the HTTP Challenge.
I also see you got a cert yesterday but just for the main domain name (not with the www subdomain).
Are you still having problems? The Let's Debug test site is helpful when setting up new web services
https://letsdebug.net
I shutdown the server, trying to resolve this issue (creating a new server at the moment), thats why you cant access HTTP at the moment.
however, when it was online I cloud access HTTP via public.
Ill respond to this post once I get the error again.
yes, I did x2 renewals yesterday on cloud.
thank you
nothing yet...
curl -Ii cloud.itwindow.co.za
curl -Ii www.cloud.itwindow.co.za
