My domain is: electronicformswebservice.wellbridge.com
I ran this command: letsencrypt-win-simple.v1.9.7.0\letsencrypt.exe
It produced this output: code 429 (My apologies. I’m no longer able to generate the error, so I don’t have the full output).
My web server is (include version): IIS version 7.5.7600.16385
The operating system my web server runs on is (include version): Windows Server 2008 R2 Standard
My hosting provider, if applicable, is: not applicable
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 1.9.7.0
Hello.
On a server running Windows Server 2008 R2 Standard, a certificate was created using Let’s Encrypt (letsencrypt-win-simple.v1.9.7.0).
The certificate, set to expire on 06/19/2019, was assigned to a web service hosted by IIS.
When the certificate was created, a task was added to Task Scheduler so that the certificate would be automatically renewed.
Yesterday, 06/19/2019, applications accessing the web service crashed because the certificate had not been renewed.
When I tried to manually renew it, error 429 was returned.
Using https://tools.letsdebug.net/, I have identified multiple certificates created by Let’s Encrypt (via Task Scheduler), which explains error 429.
Since Let’s Encrypt is launched on a daily basis, there is one certificate per day since 05/16. For some reason, none of the new certificates has replaced the one that was set to expire on 06/19/2019.
By manually assigning one of these certificates to the web service, applications accessing it are working again.
Is this a known issue?
Is there something that could be done to fix it?
Thank you for your assistance.
pm_wb
