Certs issued by CN=R3 are not recognized
My domain is: s.hdnux.com
curl -v --resolve s.hdnux.com:443:98.129.228.59 https://s.hdnux.com/photos/01/15/65/46/20404665/3/ratio3x2_300.jpg
* TLSv1.2 (OUT), TLS alert, unknown CA (560):
* SSL certificate problem: unable to get local issuer certificate
apache2 2.4.7-1ubuntu4.8
Ubuntu 14.04
Rackspace
certbot 0.26.1
We have 135 certs that are renewed on a rolling basis. Four of them renewed last night and this morning our CDN, Fastly, was unable to connect to origin because they do not recognize the new certs. The certs are:
s.hdnux.com
newstimes.com
stamfordadvocate.com
greenwichtime.com
The prior certs were issued by:
issuer= /C=US/O=Let's Encrypt/CN=Let's Encrypt Authority X3
The problematic certs were issued by:
issuer= /C=US/O=Let's Encrypt/CN=R3
Hi @pmastren
there is no Letsencrypt certificate, there is a GlobalSign certificate.
So it's impossible to check your server.
That's changed. Your server must send the new R3 certificate. If not, the error is expected.
Hello @pmastren,
It is a bit strange that you are testing your server pointing to ip 98.129.228.59 instead of the ip resolved by your dns but... the problem is that you are not serving the Let's Encrypt chain in your Apache conf so you are not serving the intermediate cert (R3):
$ echo | openssl s_client -connect 98.129.228.59:443 -servername s.hdnux.com -showcerts 2>/dev/null | grep '^ [0-1]'
 0 s:CN = s.hdnux.com
If you were serving the intermediate certificate you should see one more line:
If you paste your apache conf we could show you the right conf.
Edit: I didn't see you were using Apache 2.4.7 so in this case, you should have a line like this in the VirtualHost where you are defining the SSL directives:
SSLCertificateChainFile /etc/letsencrypt/live/s.hdnux.com/chain.pem
Cheers,
sahsanu
There is a cert issued:
crt.sh | 3839647697
The problem is within your system (that's doing the curling).
It must needs an update to the /etc/ssl/certs/ca-certificates.crt file.
Mine has a size of 233394 and is dated Mar 6, 2019.
Need I say more?
If you try to issue the same command @pmastren is using, you will receive the same error (it doesn't matter whether you have the ca certificates up to date) :wink:
$ curl -v --resolve s.hdnux.com:443:98.129.228.59 https://s.hdnux.com/photos/01/15/65/46/20404665/3/ratio3x2_300.jpg                                  60 < 00:38:39
* Added s.hdnux.com:443:98.129.228.59 to DNS cache
* Hostname s.hdnux.com was found in DNS cache
*   Trying 98.129.228.59:443...
* TCP_NODELAY set
* Connected to s.hdnux.com (98.129.228.59) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
*   CAfile: /etc/ssl/certs/ca-certificates.crt
  CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* Closing connection 0
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
@sahsanu, I do now see what you see.
And can confirm is with:
And also to the default cert name provided by the IP:
Address:  98.129.228.59
curl -v https://newstimes.com/
*   Trying 98.129.228.59...
* TCP_NODELAY set
* Connected to newstimes.com (98.129.228.59) port 443 (#0)
* ALPN, offering h2
* TLSv1.2 (OUT), TLS alert, Server hello (2):
* stopped the pause stream!
