My domain is: dipstik.info
I ran this command: sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/dipstik.info.conf
dns-01 challenge for dipstik.info
Attempting to renew cert (dipstik.info) from /etc/letsencrypt/renewal/dipstik.info.conf produced an unexpected error: Missing command line flag or config entry for this setting:
NOTE: The IP of this machine will be publicly logged as having requested this certificate. If you're running certbot in manual mode on a machine that is not your server, please ensure you're okay with that.
Are you OK with your IP being logged?
(You can set this with the --manual-public-ip-logging-ok flag). Skipping.
/etc/letsencrypt/live/dipstik.info/fullchain.pem (failure)
I am running a python based server (python 2.7 using SimpleHTTPServer)
The operating system my web server runs on is (include version): Ubuntu 20.04 LTS
My hosting provider, if applicable, is: Digital Ocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.40.0
I have recently attempted to upgrade a simple HTTP site to use HTTPS and be compliant with modern browsers.
I was originally running on Ubuntu 18.04 and managed to set up the system using letsencrypt. It appeared to work. Due to some general system reliability issues, I have now upgraded to Ubuntu 20.04. Now I am having issues with challenge failures and renewal failures as above.
I originally used guidance from this document How To Acquire a Let's Encrypt Certificate Using DNS Validation with acme-dns-certbot on Ubuntu 18.04 | DigitalOcean
to set up my system.
The system was originally set up using certbot 0.31.0
I am hoping someone might have seen this behaviour and can offer some guidance.
Despite these issues, my website is basically running but I suspect I will have a problem when I need to renew the certificates in a a few months.
Cheers
Peter.
