I have a server with 15 websites, i all migrated in https 2 month ago.
Now, i have to renew the certificates, but i got some troubles.
I launch the command ‘/certbot-auto renew --no-self-upgrade’ all the day, and after few launch, only 2-3 certificates were upgraded, and i don’t why. It’s working once in a while.
I checked everything. All the websites works in http (80) and https (443). There a 301 redirection between http->https.
The DNS seems ok. And there is no firewall. I’m using apache.
Exemple of website passed after few try: https://www.xdla.com and another one wich did not pass after 20 tries: www.piscine-en-palette.fr
I read all the topics about my trouble, with no success…
The error is always the same:
Domain: www.piscine-en-palette.fr
Type: connection
Detail: Timeout
Domain: piscine-en-palette.fr
Type: connection
Detail: Timeout
The result of /var/log/letsencrypt/letsencrypt.log:
letsencrypt.txt
A few lines:
2017-06-28 18:00:32,388:DEBUG:acme.client:Sending GET request to https://acme-v01.api.letsencrypt.org/acme/authz/h1gX8AAPrKbB3oIRbgVVUeO88fAlgak5CjQR9I7r7iE.
2017-06-28 18:00:32,611:DEBUG:requests.packages.urllib3.connectionpool:https://acme-v01.api.letsencrypt.org:443 “GET /acme/authz/h1gX8AAPrKbB3oIRbgVVUeO88fAlgak5CjQR9I7r7iE HTTP/1.1” 200 1520
2017-06-28 18:00:32,612:DEBUG:acme.client:Received response:
HTTP 200
Server: nginx
Content-Length: 1520
Boulder-Request-Id: so1p-4wH3eJA-XsxC-IZ9N4SXs2I7fAEfjbZb5IgJQc
Link: https://acme-v01.api.letsencrypt.org/acme/new-cert;rel="next"
Replay-Nonce: 4Qteiwa7pWGxgbd77oDROZNcjWcAutX3PSYyPnfbMyY
X-Frame-Options: DENY
Expires: Wed, 28 Jun 2017 18:03:19 GMT
Cache-Control: max-age=0, no-cache, no-store
Pragma: no-cache
Date: Wed, 28 Jun 2017 18:03:19 GMT
“identifier”: {
“type”: “dns”,
“value”: “www.piscine-en-palette.fr”
“status”: “invalid”,
“expires”: “2017-07-05T18:03:07Z”,
“challenges”: [
“type”: “http-01”,
“status”: “pending”,
“uri”: “https://acme-v01.api.letsencrypt.org/acme/challenge/h1gX8AAPrKbB3oIRbgVVUeO88fAlgak5CjQR9I7r7iE/1441834297”,
“token”: “jk305netFLDmT3WhmqWFC6N3fiEOoPN4o0WHA1A-g-A”
“type”: “dns-01”,
“uri”: “https://acme-v01.api.letsencrypt.org/acme/challenge/h1gX8AAPrKbB3oIRbgVVUeO88fAlgak5CjQR9I7r7iE/1441834298”,
“token”: “GhaG-4vNd3KSr8w5v_KQi0MFUEsmaeZR2dwyEOucOnc”
“type”: “tls-sni-01”,
“error”: {
“type”: “urn:acme:error:connection”,
“detail”: “Timeout”,
“status”: 400
“uri”: “https://acme-v01.api.letsencrypt.org/acme/challenge/h1gX8AAPrKbB3oIRbgVVUeO88fAlgak5CjQR9I7r7iE/1441834299”,
“token”: “Br3-I5Mwg-xTZJWcwQrpGzI6I965bTcC5V01as7us0M”,
“keyAuthorization”: “Br3-I5Mwg-xTZJWcwQrpGzI6I965bTcC5V01as7us0M.tP5lRgXPLDHG7jBvmqYLx42c6Pke0Tr_-2wUfFVmpCs”,
“validationRecord”: [
“hostname”: “www.piscine-en-palette.fr”,
“port”: “443”,
“addressesResolved”: [
“5.135.178.75”
“addressUsed”: “5.135.178.75”,
“addressesTried”: []
“combinations”: [
0
1
2
Thanks for your help, i’m being crazy.
An sorry for my poor english.
Xavier
