Certificate renew issue on apache2
My domain is: nokelstv.com
I ran this command: sudo certbot renew
Processing /etc/letsencrypt/renewal/nokelstv.com.conf
http-01 challenge for nokelstv.com
Using the webroot path /var/www/nokelstv.com for all unmatched domains.
Challenge failed for domain nokelstv.com
Attempting to renew cert (nokelstv.com) from /etc/letsencrypt/renewal/nokelstv.com.conf produced an unexpected error: Some challenges have failed.. Skipping.
/etc/letsencrypt/live/nokelstv.com/fullchain.pem (failure)
The operating system my web server runs on is (include version): ubuntu: 20.04
My hosting provider, if applicable, is: ssdnodes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
Please I really need a response to this, the site needs to go live
Do you still need help? If so can you explain?
Because I see you got a cert today and your server is sending it out.
Yeah I fixed it. My webroot was pointing to my /var/www/ instead of /var/letsencrypt
