Hello
I am trying to issue a certificate for my domain (guriaty.com) but I am getting the following error
It looks like some of the DNS records for your domain are misconfigured.
The A record you have points to 188.93.23.106, which is a Windows IIS sever.
The AAAA records you have point to 2a00:15f8:a000:5:1:13:7:bfdc (among others), which appears to be a Linux server running Apache.
You'll want to make sure the A/AAAA records both point to the same server. If the AAAA records are wrong, you could try just removing them.
You can make these changes in your registrar control panel (DomainPeople).
