Hi Guys,
Background: UNRAID, MariaDB, NextCloud, Letsencrypt.
All apps are working great until we decided to put a cert to NC. Letsencrypt is installed properly and was able to verify the subdomain. I tried 2-methods of installing the cert both with no luck. I’m not sure if this is a CF issue, NextCloud, or Letsencrypt. CF has 2-options either DNS or DNS + HTTP proxy. When I enabled only the DNS on CF, I’m able to access NC from the outside with invalid cert and when I enabled DNS + HTTP proxy, the cert is valid but I’m getting an error 502 (bad gateway). I can telnet to port 443 from the outside but I can’t figure out why the NC page is not loading.
method 1: https://blog.linuxserver.io/2017/05/10/installing-nextcloud-on-unraid-with-letsencrypt-reverse-proxy/
method 2: https://www.youtube.com/watch?v=I0lhZc25Sro
These are the settings:
NC config.php (scrubbed)
<?php
$CONFIG = array (
‘memcache.local’ => ‘\OC\Memcache\APCu’,
‘datadirectory’ => ‘/data’,
‘instanceid’ => ‘ocr0kaov7upo’,
‘passwordsalt’ => ‘yayayayayayayaya’,
‘secret’ => ‘yayayayayayayaya’,
‘trusted_domains’ =>
array (
0 => ‘1.1.1.1’,
1 => ‘nextcloud.domain.com’,
‘overwrite.cli.url’ => ‘https://nextcloud.domain.com’,
‘overwritehost’ => ‘nextcloud.domain.com’,
‘overwriteprotocol’ => ‘https’,
‘dbtype’ => ‘mysql’,
‘version’ => ‘13.0.5.2’,
‘dbname’ => ‘nextcloud’,
‘dbhost’ => ‘1.1.1.1:3306’,
‘dbport’ => ‘’,
‘dbtableprefix’ => ‘oc_’,
‘dbuser’ => ‘user’,
‘dbpassword’ => ‘password’,
‘installed’ => true,
‘mail_smtpmode’ => ‘smtp’,
‘mail_smtpauthtype’ => ‘LOGIN’,
‘mail_from_address’ => ‘nextcloud’,
‘mail_domain’ => ‘domain.com’,
‘mail_smtphost’ => ‘2.2.2.2’,
‘mail_smtpport’ => ‘25’,
Letsencrypt nextcloud.subdomain.config
listen 443 ssl;
server_name nextcloud.*;
include /config/nginx/ssl.conf;
client_max_body_size 0;
include /config/nginx/proxy.conf;
resolver 127.0.0.11 valid=30s;
set $upstream_nextcloud nextcloud;
proxy_max_temp_file_size 2048m;
proxy_pass https://$upstream_nextcloud:443;
Any help is appreciated.
