Certificate not trusted
My domain is: zedmagicmusic.com
My website ssl license not trusted
It produced this output: not trusted
Hi @muma
where do you see that result? Checked with my browser, all ok. Checked via https://check-your-website.server-daten.de/?q=zedmagicmusic.com#url-checks - most is ok.
Your certificate
CN=zedmagicmusic.com
	05.03.2021
	03.06.2021
expires in 89 days	www.zedmagicmusic.com, zedmagicmusic.com - 2 entries
has both domain names.
Small problem: Incomplete chain - use fullchain.pem instead of cert.pem.
Hi @muma !
I agree with @JuergenAuer
Looks good to me from West Coast USA!
I can get to both www and non www no problems detected.
Screenshot_2021-03-06_06-14-13
This is what I get
zedmagicmusic.com isn't sending an intermediate certificate:
osiris@desktop tmp $ openssl s_client -connect zedmagicmusic.com:443
CONNECTED(00000003)
depth=0 CN = zedmagicmusic.com
verify error:num=20:unable to get local issuer certificate
verify return:1
verify error:num=21:unable to verify the first certificate
verify return:1
Certificate chain
 0 s:CN = zedmagicmusic.com
How did you get the certificate in the first place and how did you install it into your webserver?
What says "Advanced"?
Is there an Anti-Virus-Software with something like a "deep inspection".
Looks like you see a wrong certificate in your local network.
I pasted the private key and ssl license into my hosting account
Try clearing your cache?
@muma, what you pasted was incomplete; it was missing the intermediate certificate. This is what @JuergenAuer and @Osiris both noticed, and I can also confirm it.
What method did you use to obtain the certificate that you pasted this way? Maybe it provided some additional information elsewhere that you didn't end up using?
I copied everything
First from begin private key to its end which I pasted on private key
Then from begin certificate to the end then I pasted it on SSL certificate then uploaded both
"private key" and "certificate" is not the same as "private key", "certificate" and "intermediate certificate" though.
Most "SSL upload" features support a certificate chain (which is the end leaf certificate plus intermediate certificate) as "certificate".
Unfortunately, you haven't answered the question about how you got the certificate in the first place, so no idea where you might be able to find the intermediate provided by the ACME client you've used.
I got the certificate using infinity free admin dashboard
Welcome to the Let's Encrypt Community, Muma :slightly_smiling_face:
While it's not an automated solution, you can...
  1. Download the intermediate certificate here.
  2. Append/paste the contents of the intermediate certificate file to the bottom of your certificate file (being sure to leave a blank line between the two certificates).
  3. Upload the combined file.
