Or just make them all relative...
In Forum backend:
Board URL
The url to your forums.
Include the http://. Do NOT include a trailing slash.
https://www.techmasterdesign.com/groupfinder
Can change that to groupfinder.cc
He will be fine.
The two names are being served independently from each other (properly via SNI).
The issue will be in that the site was build on top of the first name.
Everything in there references that first name.
I’ll leave you two to it. food…
thank you for your help <3
SNI Config doesn’t look too bad, but i’m sure i’ll figure out some way to fuck it up:
# Ensure that Apache listens on port 443
Listen 443
# Listen for virtual host requests on all IP addresses
NameVirtualHost *:443
# Go ahead and accept connections for these vhosts
# from non-SNI clients
SSLStrictSNIVHostCheck off
<VirtualHost *:443>
# Because this virtual host is defined first, it will
# be used as the default if the hostname is not received
# in the SSL handshake, e.g. if the browser doesn't support
# SNI.
DocumentRoot /www/example1
ServerName www.example.com
# Other directives here
</VirtualHost>
<VirtualHost *:443>
DocumentRoot /www/example2
ServerName www.example2.org
</VirtualHost>
SNI basically means that you can/will serve multiple domains names (individually) via the same single IP.
You are already doing that.
Where:
site1 & site2 = (same) IP
site1 goes to /folder1
site2 goes to /folder2
gunna try and run certbot --apache
And then set up that A record DDNS script
(might save that for tomorrow lol)
ERR MY GERD!!! IT WERKS! NO FERKIN WEY.
THANK YOU FOR ALL YOUR HELP YOU FUCKIN GENIUS.
more baby steps…
tomorrow you learn how to ride a bike !
[and we’ll be there to hold your handlebars… and then let go! - lol]
Dr. ME says:
The less GD in your diet, the healthier your brain gets.
Rofl. I hate them but I also love them because I bet other hosting providers don’t have extensive uses of their API’s, and I wouldn’t get to use this: https://github.com/CarlEdman/godaddy-ddns
So there’s a positive side to it being a popular domain provider. Funny thing is that you would have expected the name godaddy.com to be used as a porn site, not web hosting and DNS.
It’s God Addy,
So not pornographic, but blasphemous.
Hey for some reason when going to a subdirectory without using www. it says the certicate is not valid (example domain: techmasterdesign.com/truce-photos:
"Your connection is not private
Attackers might be trying to steal your information from techmasterdesign.com (for example, passwords, messages, or credit cards). Learn more
NET::ERR_CERT_COMMON_NAME_INVALID
Help improve security on the web for everyone by sending URLs of some pages you visit, limited system information, and some page content to Google. Privacy policy"
here is the 000-default.conf in sites-available:
# for www.techmasterdesign.com
RewriteCond %{SERVER_NAME} =www.techmasterdesign.com
# for techmasterdesign.com
RewriteCond %{SERVER_NAME} =techmasterdesign.com
Because the cert in use is missing that base FQDN:
[HTTP would not have this problem but it forwards to HTTPS]
Please show:
certbot certificates
root@dell-emc:/home/george# certbot certificates
Found the following certs:
Certificate Name: www.techmasterdesign.com
Serial Number: 4823c863a3a4789ec9073c95aa7c4c2da7a
Domains: groupfinder.cc wavebuddha.com www.groupfinder.cc www.techmasterdesign.com www.wavebuddha.com
Expiry Date: 2020-12-13 04:29:31+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.techmasterdesign.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.techmasterdesign.com/privkey.pem
I guess they all share that one techmasterdesign.com certificate :O. Sorry for the late reply, I fell right asleep like a lil baby.
You are missing the techmasterdesign.com FQDN in that list.
Use:
apachectl -S
to make sure the name is covered and then add it to the cert.
AH00526: Syntax error on line 35 of /etc/apache2/sites-enabled/000-default-le-ssl.conf:
SSLCertificateFile: file ‘/etc/letsencrypt/live/www.techmasterdesign.com/fullchain.pem’ does not exist or is empty
Action ‘-S’ failed.
Try it with SUDO:
sudo apachectl -S
[empty in this case isn’t empty - it is I can’t read the file]
root@dell-emc:/home/george# sudo apachectl -S
VirtualHost configuration:
*:443 is a NameVirtualHost
default server www.techmasterdesign.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
port 443 namevhost www.techmasterdesign.com (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
port 443 namevhost groupfinder.cc (/etc/apache2/sites-enabled/groupfinder-le-ssl.conf:2)
alias www.groupfinder.cc
port 443 namevhost wavebuddha.com (/etc/apache2/sites-enabled/wavebuddha-le-ssl.conf:2)
alias www.wavebuddha.com
*:80 is a NameVirtualHost
default server www.techmasterdesign.com (/etc/apache2/sites-enabled/000-default.conf:1)
port 80 namevhost www.techmasterdesign.com (/etc/apache2/sites-enabled/000-default.conf:1)
port 80 namevhost groupfinder.cc (/etc/apache2/sites-enabled/groupfinder.conf:1)
port 80 namevhost wavebuddha.com (/etc/apache2/sites-enabled/wavebuddha.conf:1)
ServerRoot: "/etc/apache2"
Mutex proxy: using_defaults
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
Ok so I need to add the techmasterdesign.com domain in virtualhosts sites-available?
I think im missing the line ServerAlias techmasterdesign.com
