Certificate not auto-renewing
My domain is: morelandarts.com and www.morelandarts.com
I ran this command: Added a line to the Cron Job which hopefully will automatically renew.
sudo crontab -e - Launches Cron Editor
Add this line -
0 0 1 * * sudo /opt/bitnami/letsencrypt/lego --path="/opt/bitnami/letsencrypt" --email="flyntmor@gmail.com" --domains=morelandarts.com --domains=www.morelandarts.com --domains=*.morelandarts.com renew && sudo /opt/bitnami/apache2/bin/httpd -f /opt/bitnami/apache2/conf/httpd.conf -k graceful
I continue to get the "expires in 20 days
Amazon Lightsail
Bitnami
Yes
I’m a real novice at this so please be kind.
Then you should try to renew it now...
This command (if it works) puts in a job that will run automatically on the first day of the week at exactly midnight? [not sure where you got those instructions - twice a day is the recommended check]
But to the point:
You need to renew first (manually - now) and then worry about the automatic renewal job.
Try:
sudo /opt/bitnami/letsencrypt/lego --path="/opt/bitnami/letsencrypt" --email="flyntmor@gmail.com --domains=morelandarts.com --domains=www.morelandarts.com --domains=*.morelandarts.com renew && sudo /opt/bitnami/apache2/bin/httpd -f /opt/bitnami/apache2/conf/httpd.conf -k graceful
I now see you have a wildcard cert request in there - that will require a DNS modification and I don't see any DNS plugin being used, so it will have to be made manually.
Is this the first time for the wildcard?
Looks like you used to have a wildcard cert; but that expired in June:
I really do appreciate your help but I’m such a newbie at this, I have not been able to follow your instructions to manually renew. I cut and pasted the line
“sudo /opt/bitnami/letsencrypt/lego --path=”/opt/bitnami/letsencrypt" --email="flyntmor@gmail.com --domains=morelandarts.com --domains=www.morelandarts.com --domains=*.morelandarts.com renew && sudo /opt/bitnami/apache2/bin/httpd -f /opt/bitnami/apache2/conf/httpd.conf -k graceful"
As you suggested, and the only response I rec’d was >. I can’t tell that anything happened? I went to the “check your website” server and it still indicates my certificate expires in 10 days.
The > is a prompt from your shell (command interpreter) indicating that it’s waiting for more input from you because there is an opening quotation mark without a matching closing quotation mark.
In this case, that happened because @rg305’s suggestion contained a typo: there should have been a " after the e-mail address flyntmor@gmail.com, but it’s missing. This made the shell think that you hadn’t finished typing in the command yet, because valid shell commands need to have paired opening and closing quotes. (Adding a " at the very end of the line would have prevented the > from appearing, but the command would still have been wrong in a different way.)
A corrected version of @rg305’s suggested command is
sudo /opt/bitnami/letsencrypt/lego --path="/opt/bitnami/letsencrypt" --email="flyntmor@gmail.com" --domains=morelandarts.com --domains=www.morelandarts.com --domains="*.morelandarts.com" renew && sudo /opt/bitnami/apache2/bin/httpd -f /opt/bitnami/apache2/conf/httpd.conf -k graceful
(I haven’t verified the correctness of any part of that except for the placement of the quotation marks.)
Thanks so much for your help but…
When I enter the command you provided, I get this message:
2019/11/22 13:43:34 No challenge selected. You must specify at least one challenge: --http, --tls, --dns.
After “we” get this to work, I sure hope “we” can figure out what I’m doing wrong on the auto renew function.
Try adding (to that long command):
--http
[before the &&]
Still no joy… Here’s the command I entered:
sudo /opt/bitnami/letsencrypt/lego --path="/opt/bitnami/letsencrypt" --email="flyntmor@gmail.com" --domains=morelandarts.com --domains=www.morelandarts.com --domains="*.morelandarts.com" renew --http && sudo /opt/bitnami/apache2/bin/httpd -f /opt/bitnami/apache2/conf/httpd.conf -k graceful
Here’s the response:
Incorrect Usage: flag provided but not defined: -http
NAME:
lego renew - Renew a certificate
USAGE:
lego renew [command options] [arguments…]
OPTIONS:
–days value The number of days left on a certificate to renew it. (default: 30)
–reuse-key Used to indicate you want to reuse your current private key for the new ce
rtificate.
–no-bundle Do not create a certificate bundle by adding the issuers certificate to th
e new certificate.
–must-staple Include the OCSP must staple TLS extension in the CSR and generated certif
icate. Only works if the CSR is generated by lego.
–renew-hook value Define a hook. The hook is executed only when the certificates are effecti
vely renewed.
2019/11/22 20:59:39 flag provided but not defined: -http
bitnami@ip-172-26-12-170:~$
I’m afraid I don’t even know enough to make an educated guess as to what to try.
I believe that --http has to come before the word renew.
According to Lego’s source code, http needs to be a “global” flag rather than a flag of the renew subcommand.
OK… that appears to be progress.
Here’s the command:
rypt" --email=flyntmor@gmail.com --domains=morelandarts.com --domains=www.morelandarts.com
–http renew && sudo /opt/bitnami/apache2/bin/httpd -f /opt/bitnami/apache2/conf/httpd.con
f -k graceful
And the Response:
2019/11/22 21:59:05 You have to pass an account (email address) to the program using --email or -m
Again, thanks so much for your help!
I noticed the quotes around my email address so I tried this:
sudo /opt/bitnami/letsencrypt/lego --path="/opt/bitnami/letsencrypt" --email="flyntmor@gmail.com" --domains=morelandarts.com --domains=www.morelandarts.com --http renew && sudo /opt/bitnami/apache2/bin/httpd -f /opt/bitnami/apache2/conf/httpd.conf -k graceful
Same results:
2019/11/23 23:33:37 You have to pass an account (email address) to the program using --email or -m
Arrrrgh, I need help.
When I run that exact same command with lego v3.2.0, it does not complain about the email address.
I would double check that you are not accidentally doing something weird when you run in the terminal, like missing a space between parameters.
Try it as this:
sudo /opt/bitnami/letsencrypt/lego --path="/opt/bitnami/letsencrypt" --email "flyntmor@gmail.com --domains "morelandarts.com,www.morelandarts.com" --http renew && sudo /opt/bitnami/apache2/bin/httpd -f /opt/bitnami/apache2/conf/httpd.conf -k graceful
I did a cut and paste, then checked the line char by char. I got a different response this time. Here’s the command:
sudo /opt/bitnami/letsencrypt/lego --path="/opt/bitnami/letsencrypt" –email=“flyntmor@gmail.com” --domains=morelandarts.com --domains=www.morelandarts.com --http renew && sudo /opt/bitnami/apache2/bin/httpd -f /opt/bitnami/apache2/conf/httpd.conf -k graceful
No help topic for ‘–email=flyntmor@gmail.com’
bitnami@ip-172-26-12-:~$
What am I doing wrong? Please keep the input coming…
That's not a double dash.
Your copy/paste program mashed them into a single long -
Yea! I see signs of progress, but I don’t know what to do from here?
2019/11/24 03:25:32 No key found for account “flyntmor@gmail.com”. Generating a P384 key.
2019/11/24 03:25:32 Saved key to /opt/bitnami/letsencrypt/accounts/acme-v02.api.letsencrypt
.org/“flyntmor@gmail.com”/keys/“flyntmor@gmail.com”.key
2019/11/24 03:25:32 Account “flyntmor@gmail.com” is not registered. Use ‘run’ to register a
new account.
I tried entering “RUN”
You should probably find and read through the documentation before continuing; as you are requesting certs from the live system (not test/staging).
I’m trying to renew the certificate for an existing live site. I think I have 8 days left.
Before I started asking for help, I went through the procedures listed in 2 documents, with no luck. I have been unable to find a document that describes how to renew manually. I was hoping that if I could figure out how to do it manually, then maybe I could figure out why my auto-renew is not working.
I am admittedly over my head and I really do appreciate the help.
Unless you know for sure, you should “test” in the “test” system.
The last thing you want is just as you “figure it out” you get blocked for 5 days.
Issuing a test cert is equally challenging…
Figure that out and your set with the live system.
Can you suggest a document for me to reference?
Sadly the only Lego® I know of is not computerized (they are hard little plastic pieces - LOL)
I would be glad to help search for one… But I don’t know of anything off hand.
So far:
These are included
--tls
--days 90
[not sure why]
https://go-acme.github.io/lego/usage/cli/examples/
Shows only:
To renew the certificate
lego --email="foo@bar.com" --domains="example.com" --http renew
