HI,
My domain is: www.datacook.org and I created the SSL certificates both datacook.org and www.datacook.org .
But currently www.datacook.org is showing that it is not trusted. and getting an error as following.
www.datacook.org somehow checks the certificate of ‘datacook.org ’ without www and complains with “certificate name does not match input”.
I am not sure if this is a DNS issue? or certificate issue?
sudo certbot certificates
Found the following certs:
Certificate Name: datacook.org
Domains: datacook.org
Expiry Date: 2019-09-17 23:22:20+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/datacook.org/fullchain.pem
Private Key Path: /etc/letsencrypt/live/datacook.org/privkey.pem
Certificate Name: www.datacook.org
Domains: www.datacook.org
Expiry Date: 2019-09-18 01:14:19+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.datacook.org/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.datacook.org/privkey.pem
Osiris
June 20, 2019, 5:07am
2
How did you create that certificate? What was the command line?
Hi @yuneebird
you have created some certificates ( https://check-your-website.server-daten.de/?q=datacook.org ):
CertSpotter-Id
Issuer
not before
not after
Domain names
LE-Duplicate
next LE
976144108
CN=Let’s Encrypt Authority X3, O=Let’s Encrypt, C=US
2019-06-20 01:14:19
2019-09-18 01:14:19
www.datacook.org - 1 entries
duplicate nr. 2
976008230
2019-06-19 23:22:20
2019-09-17 23:22:20
duplicate nr. 1
976002670
2019-06-19 23:18:59
2019-09-17 23:18:59
datacook.org , www.datacook.org - 2 entries
duplicate nr. 1
975972042
2019-06-19 22:56:56
2019-09-17 22:56:56
duplicate nr. 1
One with both domain names, three with one domain name.
But you use only one certificate
CN=datacook.org
20.06.2019
18.09.2019
expires in 90 days datacook.org - 1 entry
So:
You have one vHost with both domain names (that’s good, there are not two vHosts with two different certificates required),
but that vHost uses the wrong certificate
So try
certbot -d datacook.org -d www.datacook.org --reinstall
Then certbot should find the certificate with both domain names.
But: What’s your server software? There is no server header (Apache or nginx).
Did you use certonly? If yes, you have to install the certificate manual.
I had to user certonly. and when I ran certbot, I selected the option standalone and it worked. thank you. This is really helpful. We can close this issue.
Spin up a temporary webserver (standalone)
One more question, to JuergenAuer . How can I renew the certificate in 90 days? Could you share the command please?
When I validate the SSL, there is red warning that “Incorrect certificate because this client doesn’t support SNI”, Any recommendations?
Osiris
June 21, 2019, 5:14am
7
yuneebird:
Update your ancient client. SNI is, in computer terms, very old, and should be supported by all modern clients.
Certbot should have created a cron job. But certonly -> perhaps you have to install the certificate manual.
So check your configuration in 65 days to see, if there is a new certificate.
Where do you see that warning? Via Ssllabs, the part with
Certificate #2: ... No SNI
Then ignore it. Or do you have XP users with IE6 you have to support?
The part from Certificate #1 is relevant.
system
Closed
July 21, 2019, 7:29am
10
