My domain is: smartvibes.be and partneralacarte.be
certbot certonly --force-renew -d smartvibes.be -d www.smartvibes.be -d partneralacarte.be -d www.partneralacarte.be
[root@server live]# certbot certonly --force-renew -d smartvibes.be -d www.smartvibes.be -d partneralacarte.be -d www.partneralacarte.be
1: Apache Web Server plugin - Beta (apache)
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press ‘c’ to cancel): 3
http-01 challenge for smartvibes.be
http-01 challenge for www.smartvibes.be
http-01 challenge for partneralacarte.be
http-01 challenge for www.partneralacarte.be
Select the webroot for smartvibes.be:
1: Enter a new webroot
Press 1 [enter] to confirm the selection (press ‘c’ to cancel): /var/www/html/smartvibes.be/
** Invalid input **
Press 1 [enter] to confirm the selection (press ‘c’ to cancel): 1
Input the webroot for smartvibes.be: (Enter ‘c’ to cancel): /var/www/html/smartvibes.be/
Select the webroot for www.smartvibes.be:
2: /var/www/html/smartvibes.be
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
Select the webroot for partneralacarte.be:
Select the webroot for www.partneralacarte.be:
Waiting for verification…
/etc/letsencrypt/live/partneralacarte.be/fullchain.pem
/etc/letsencrypt/live/partneralacarte.be/privkey.pem
Your cert will expire on 2018-09-01. To obtain a new or tweaked
version of this certificate in the future, simply run certbot
again. To non-interactively renew all of your certificates, run
“certbot renew”
My web server is (include version): apache
The operating system my web server runs on is (include version): centos
My hosting provider, if applicable, is: Nucleus
So, the certification renewal on smartvibes.be now works just fine.
At partneralacarte.be I get a mismatch error. It says the certificate is assigned to smartvibes.be
Don’t know what to do.
I tried to create a new certificate for partneralacarte but then I receive a certification-week-limit error.
Off course I’d prefer fixing this instead of creating a new certificate.
