Certificate issues - works in chrome but not IE
My domain is: https://www.appreciateatnationalgrid.com/
I ran this command: N/A
It produced this output: certificate error in IE stating issued for a different website address
My web server is (include version): n/a
The operating system my web server runs on is (include version): n/a
My hosting provider, if applicable, is: n/a
I can login to a root shell on my machine (yes or no, or I don’t know): n/a
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): n/a
Hi @james.mountford
your https://www.appreciateatnationalgrid.com/ doesn't work. You have a certificate with only one name:
DNS-Name: appreciateatnationalgrid.com
So create a new certificate with two names:
appreciateatnationalgrid.com www.appreciateatnationalgrid.com
With Certbot, it's something like
certbot -d appreciateatnationalgrid.com -d www.appreciateatnationalgrid.com ...[other parameter]
hello @JuergenAuer
thank you for your response and advice. I was under the impression letsencrypt created and applied the certificates for this URL, is that correct?
many thanks
james
Letsencrypt does that what you want. If you order only a certificate with one name appreciateatnationalgrid.com - you get that.
How did you create that certificate?
thank you, we have now resolved the issue with your advice
