Certificate is not Valid
kaskie-family.no-ip.org
sudo certbot --apache
succss
apchache 2.4.18
ubuntu
Server is running on site
no
I am getting the following in Chrome:
Your connection is not private
Attackers might be trying to steal your information from kaskie-family.no-ip.org (for example, passwords, messages, or credit cards). Learn more
NET::ERR_CERT_REVOKED
With this certificate information:
SSL Server Certificate
Common Name (CN) kaskie-family.no-ip.org
Organization (O)
Organizational Unit (OU)
Common Name (CN) StartCom Class 1 DV Server CA
Organization (O) StartCom Ltd.
Organizational Unit (OU) StartCom Certification Authority
Issued On Wednesday, March 22, 2017 at 10:28:02 AM
Expires On Sunday, March 22, 2020 at 10:28:02 AM
SHA-256 Fingerprint EA EE C4 1F 51 46 F1 EC D0 50 06 9E 96 58 AC 5F
00 41 0D 85 82 F0 E7 40 2B DE 9B CD C5 DC 3A C0
SHA-1 Fingerprint 75 AF 14 AB 88 2F 03 12 C7 DD 69 C1 00 7F 80 DB
01 45 90 08
Also, my default-ssl.conf:
		ServerName kaskie-family.no-ip.org
	ServerAlias www.kaskie-family.no-ip.org
	DocumentRoot "/var/www/html"
	SSLCertificateFile /etc/letsencrypt/live/kaskie-family.no-ip.org/fullchain.pem
	SSLCertificateKeyFile /etc/letsencrypt/live/kaskie-family.no-ip.org/privkey.pem
	SSLCertificateChainFile /etc/letsencrypt/live/kaskie-family.no-ip.org/chain.pem
Can you try to restart the Apache?
(Just in case certbot didn’t)
Also, please run this command and share us the output. apache2ctl -S
Thank you
You’re using an old certificate issued by StartCom. However, you’ve issued two certificates from Let’s Encrypt today
https://crt.sh/?Identity=%kaskie-family.no-ip.org&iCAID=16418
But your web server isn’t using either of them. Did you do something to configure your server to use the newly-issued certificates after you issued them?
I had a hard time stopping apache! Had to run “killall” but finally got it to stop. Restarted it.
Getting this now:
This site can’t provide a secure connection
kaskie-family.no-ip.org sent an invalid response.
ERR_SSL_PROTOCOL_ERROR
apache2ctl -S
AH00526: Syntax error on line 21 of /etc/apache2/sites-enabled/default-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/wafka.no-ip.org/fullchain.pem' does not exist or is empty
Action '-S' failed.
The error is referring to a different VirtualHost. But to be safe, I renewed that certificate.
Congratulations! You have successfully enabled https://wafka.no-ip.org
https://www.ssllabs.com/ssltest/analyze.html?d=wafka.no-ip.org
    /etc/letsencrypt/live/wafka.no-ip.org/privkey.pem
    Your cert will expire on 2018-08-18. To obtain a new or tweaked
    with the “certonly” option. To non-interactively renew all of
    your certificates, run “certbot renew”
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
Okay…
Can you check if those are okay? (I mean, can you try to get the Apache running… with no error?)
And them the issue might just resolved.
P.S. please check if there is any duplicate vHosts which might override the host (using startcom certs). Also, check if your domain is matching with the IP address…(just in case it doesn’t…)
Thank you
Still not working, but new error:
I also got rid of the other vhost, just to test. and now running the apache2ctl -S shows this:
AH00526: Syntax error on line 27 of /etc/apache2/sites-enabled/default-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/kaskie-family.no-ip.org/fullchain.pem' does not exist or is empty
Action '-S' failed.
And this is the results of the SSL test:
There are some errors that we cannot fix properly in the current version. They will be addressed in the next generation version, which is currently being developed.
No secure protocols supported - if you get this message, but you know that the site supports SSL, wait until the cache expires on its own, then try again, making sure the hostname you enter uses the "www" prefix (e.g., "www.ssllabs.com", not just "ssllabs.com").
no more data allowed for version 1 certificate - the certificate is invalid; it is declared as version 1, but uses extensions, which were introduced in version 3. Browsers might ignore this problem, but our parser is strict and refuses to proceed. We'll try to find a different parser to avoid this problem.
Failed to obtain certificate and Internal Error - errors of this type will often be reported for servers that use connection rate limits or block connections in response to unusual traffic. Problems of this type are very difficult to diagnose. If you have access to the server being tested, before reporting a problem to us, please check that there is no rate limiting or IDS in place.
NetScaler issues - some NetScaler versions appear to reject SSL handshakes that do not include certain suites or handshakes that use a few suites. If the test is failing and there is a NetScaler load balancer in place, that's most likely the reason.
Unexpected failure - our tests are designed to fail when unusual results are observed. This usually happens when there are multiple TLS servers behind the same IP address. In such cases we can't provide accurate results, which is why we fail.
Does that file actually exist? Have you manually deleted or renamed anything within /etc/letsencrypt?
Please show these four (you can post replies individually if you like):
sudo certbot certificates
grep -Eri 'servername|serveralias' /etc/apache2
grep -Eri 'SSLProtocol|SSLCipherSuite' /etc/apache2
netstat -pant | grep -i listen
