Certificate expired web site not secured
My domain is: repdom-roots.com or capvert-roots.com or islande-roots.com or newyio
It produced this output: page not secured certificate expired
My web server is (include version): ovh
My hosting provider, if applicable, is: ovh
Please answer all the questions to the best of your knowledge. This is mandatory to get adequate help.
The operating system my web server runs on is (include version): ? Windows 2016
System (OS)
Debian 6.0 LTS (“Squeeze”) (oldoldstable) (End of Life: February 29, 2016)
I can login to a root shell on my machine (yes or no, or I don’t know): ? only mode rescue
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): plesk
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):–?
The message when we try to go to our domain show the following :
Your connection is not private
Attackers might be trying to steal your information from www.japon-roots.com (for example, passwords, messages, or credit cards). Learn more
NET::ERR_CERT_AUTHORITY_INVALID
Help improve Chrome security by sending URLs of some pages you visit, limited system information, and some page content to Google. Privacy policy
Back to safetyHide advanced
This server could not prove that it is www.japon-roots.com ; its security certificate is not trusted by your computer’s operating system. This may be caused by a misconfiguration or an attacker intercepting your connection.
Proceed to www.japon-roots.com (unsafe)
I don't know what "mode rescue" means.
Did you also use Plesk to get and install the certificates?
Hello , i am not sure i am not the person that installed the certificate and configurate the server.
Well, without proper answers to the “root” question and if your certificate was installed by Plesk or not it’s very hard to help you.
no i got the anwear he didn’t use plesk just SSH
OK, well, then you need to figure out two things:
  • how to get root access
  • what client was used to get the certificate (could be certbot so you might try running certbot certificates to see any certificates on your system if certbot was used)
Here the procedure he used to installed the certifdicate
He connected on cerbot in SSH
He put apache on the section my service web running
The problem is the servor is debian 6 and i am not sure i can renew today the expired let’s encrypte certificate on debian 6.
Also he used a old version of php older than php 5.6
So the question is can i renew my certificate on debian 6 ?
Or should i use other certificate ?
all my site are down now
So you're using certbot.
What does certbot renew do? And please don't answer just "it didn't work" if it doesn't work, but also give the actual output of the command.
So if i download cerbot certificate it will renew my SSL certificate ? on Debian 6 ?
Thank you
I do have the root access
Yes i do have the root access and he used cerbot so i will try to install the cerbot certificate
The program certbot should be already installed if it was previously used on this server. You should be able to just run the command certbot certificates and certbot renew in SSH (as root). No downloading required.
Thank you i will try this am and let you know how it goes
thank you
