Certificate expired - certs are not due for renewal yet
My domain is: jla787.com
I ran this command: letsencrypt renew
Processing /etc/letsencrypt/renewal/jla787.com.conf
  /etc/letsencrypt/live/jla787.com/fullchain.pem (skipped)
No renewals were attempted.
nginx version: nginx/1.10.3 (Ubuntu)
Ubuntu 16.04.1 LTS
ramnode
no
Looks like my browser sees the old crt.sh IDs logged at 2018-07-09, and not the newer ones
Nginx error logs have OCSP errors :
2018/10/20 07:24:47 [error] 2402#2402: OCSP_check_validity() failed (SSL: error:2707307D:OCSP routines:OCSP_check_validity:status expired) while requesting certificate status, responder: ocsp.int-x3.letsencrypt.org
But when I click to check OCSP status from the latest IDs on crt.sh, the status returns Good
I am stabbing in the dark beyond my ken.
If you run "sudo letsencrypt certificates", what does it show? If you're running letsencrypt 0.4.1 from the Ubuntu repository, it probably doesn't support that command, and it will just give an error, but it's worth a shot.
What does "sudo openssl x509 -dates -noout -in /etc/letsencrypt/live/jla787.com/fullchain.pem" show?
If you run "sudo nginx -T", what ssl_certificate and ssl_certificate_key directives does it show?
Does "sudo systemctl reload nginx" help?
What command did you use to get the certificate originally?
There is a certificate in existence:
It was issued on September 10, which is just right for Certbot's default renewal settings.
The question is why your web server isn't using it.
Is the clock correct? 2018-10-20 was a while ago. Are there more recent errors?
letsencrypt: error: unrecognized arguments: certificates
sudo openssl x509 -dates -noout -in /etc/letsencrypt/live/jla787.com/fullchain.pem notBefore=Sep 10 08:47:08 2018 GMT notAfter=Dec 9 08:47:08 2018 GMT
sudo nginx -T | grep ssl_certificate ssl_certificate /etc/letsencrypt/live/jla787.com/fullchain.pem; ssl_certificate_key /etc/letsencrypt/live/jla787.com/privkey.pem;
I can't remember. This is from my history:
sudo letsencrypt certonly --webroot -w /var/www/html -d jla787.com -d lotgd.jla787.com
Yes
2018/11/04 07:55:20 [error] 2402#2402: OCSP_check_validity() failed (SSL: error:2707307D:OCSP routines:OCSP_check_validity:status expired) while requesting certificate status, responder: ocsp.int-x3.letsencrypt.org
Hi @razermackham
checked your website, I see a valide certificate.
com
Created 2018-09-10, so there is no renew required.
Is it only a cache problem of your browser?
Your server is using the new certificate now. :smile:
Did "sudo systemctl reload nginx” do the trick?
When you use “certonly --webroot”, you have to configure something to reload Nginx after the certificate is renewed. Certbot can do this if you pass “--renew-hook 'systemctl reload nginx’” to it.
(For future reference, --deploy-hook is preferred in newer versions of Certbot.)
If I remember correctly, there’s a directory in /etc/letsencrypt/ where you can put shell scripts that run on renewal. /etc/letsencrypt/renew-hooks.d/ or something like that.
(This was a nonstandard thing provided by the package. In newer versions of Certbot, it’s built-in and called /etc/letsencrypt/renewal-hooks/deploy/.)
Yes. I was reading about Certbot in other posts. Seems like I need to update :slight_smile:
