Problems to renew certificates
My domain is: gleich.spdns.de
I ran this command: sudo letsencrypt renew
Processing /etc/letsencrypt/renewal/gleich.spdns.de-0001.conf
Cert not yet due for renewal
  /etc/letsencrypt/live/gleich.spdns.de-0001/fullchain.pem expires on 2020-06-08 (skipped)
No renewals were attempted.
My web server is (include version): Nginx
The operating system my web server runs on is (include version): Raspbian
My hosting provider, if applicable, is: none
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
You issued two certificates on Saturday and another one today. You don't need to renew your certificate a fourth time. (And you are close to the duplicate certificate rate limit.)
Can you explain what's wrong?
If I access https://gleich.spdns.de/, I get an Apache server using an expired Let's Encrypt certificate.
If that's the problem, you should make sure your web server -- Apache or Nginx -- is configured to use the correct files, and that it has been reloaded or restarted.
Thanks for helping. This is the solution.
I dont know why a second certificate was created, but it was the wrong one used by my nextcloud instance.
Topic can be closed.
