Certificate expired but don't have info of certificate except where it was issued
My domain is:Edisonlearning.com
I ran this command:none
It produced this output:certificate expired
The operating system my web server runs on is (include version):office365
I can login to a root shell on my machine (yes or no, or I don't know):no
Renewing is totally and 100 % dependend on how you got the certificate in the first place, as Let's Encrypt certificates are meant to be automatically renewed.
Also, how do you manage your site? You've filled in "no" at the root question as wel as the control panel question. Usually, that would make managing a site very difficult, let alone issuing and renewing a certificate.
Also nr 2: it seems you've bought (?) a certificate today (and also 5 days ago)? (crt.sh | Edisonlearning.com) Do you still require help with your Let's Encrypt certificate? Note that for help with certificates from other Certificate Authorities, you should consult with the available support sections of those Certificate Authorities.
edisonlearning.com itself has a valid certificate. The site is being hosted another vendor.
What is happening is that a cert that was assigned expired and our outlook users, despite using office 365, are getting notifications that the cert from letsencrypt.org has expired.
The previous manager of the email system set this cert up did not left any credentials to update the cert.
Thank you for looking at this
Hi @edisonlearning,
Currently www.edisonlearning.com (which is working) points at HubSpot (maybe "another vendor" in your message above), while edisonlearning.com (which is not working, with the expired certificate) points at 3.220.40.113 (most likely a VPS hosted by Amazon Web Services). Who, if anyone, is the administrator of this server, and what access, if any, do you have to control or administer it?
If you or your organization literally has no administrative access to this server now, then that's a much deeper problem.
I will check to see who has access to this
