Greetings. I am working on projects from home. Since this is at home, it's a regular cable modem to wireless router arrangement. External ports 80 and 443 and port forwarded in the router to the internal IP of the linux webserver 192.168.1.100.
I also need to share project files back and forth with colleagues. Owncloud comes as a virtual machine appliance that is entirely self contained and runs under Oracle VirtualBox -- 192.168.1.200 on the same computer that is the web server.
I tried using ownCloud's Let's Encrypt module to specify owncloud.mydomain.com . I have the DNS record set up with a CNAME of owncloud.mydomain.com to point to the IP address of my house. Since ports 80 and 443 are already being used by a Linux webserver at my house, I set up the router to redirect incoming Port 121 traffic to the virtual machine's Port 443 (192.168.1.200).
I can reach the ownCloud server at https://owncloud.mydomain.com:121 but the browser says:
"Your connection is not private
Attackers might be trying to steal your information from owncloud.stellar7.space (for example, passwords, messages, or credit cards). Learn more
NET::ERR_CERT_COMMON_NAME_INVALID"
So how do I get HTTPS with 2 different domains, accessing two different computers with 2 different LAN IPs at the same cable modem/router?
Thanks!
www.mydomain.com:80 ,443 ---> home IP --> router --> 192.168.1.100 (80,443 - webserver)
owncloud.mydomain.com:121 --> home IP --> router --> 192.168.1.200 (443 - owncloud https)
rg305
June 5, 2021, 11:34pm
2
In order for both to pass HTTP validation, you will need to direct requests to there expected end points.
This can be done via proxy.
[OR choose another authentication method - like: DNS]
I think I got it working by changing the router's port forwarding by temporarily switching the direction of Ports 80 and 443 from the webserver (192.168.1.100) to the OwnCloud appliance (192.168.1.200), then running the Let's Encrypt plugin. When I changed the router back to sending Port 80 and 443 back to the webserver (192.168.1.100) and added a routing of Port 200 to 443 at the Appliance's IP (192.168.1.200), I can now access ownCloud securely via https://mydomain.com:200/
Will I need to renew the certificate every 3 months manually by temporarily changing the port mappings to expose the ownCloud appliance to ports 80 and 443?
_az
June 6, 2021, 12:04am
4
Yes, but either of @rg305 's suggestions would enable you to avoid this fate.
Setting up a reverse proxy behind your router is a good solution also because it also means that you don't need to pick different external ports for your appliances; everything can share 80/443 externally, and then internally you'd proxy the appropriate internal host by hostname.
I don't really know anything about networking. What proxy solution would you recommend?
_az
June 6, 2021, 12:16am
6
You could set up a virtual machine that runs the nginx web server - that's very popular and Certbot has native support for it.
Let's say, you install it on a new, small virtual machine at 192.168.1.300.
You'd configure nginx to proxy for your two domains:
listen 80;
server_name mydomain.com
proxy_pass http://192.168.1.100;
listen 80;
server_name owncloud.mydomain.com
proxy_pass http://192.168.1.200;
and you'd point external ports 80 and 443 towards 192.168.1.300:80 and 192.168.1.300:443, respectively.
You could then set some certificates up (on this proxy VM):
certbot --nginx -d mydomain.com
certbot --nginx -d owncloud.mydomain.com
and from there, you can access https://owncloud.mydomain.com and https://mydomain.com directly, without needing to specify alternate ports. Certificate renewal will also be automatic and won't require any human intervention.
That's an abridged version, but there's a bunch of great "nginx + reverse proxy" tutorials out there.
rg305
June 6, 2021, 4:56am
7
_az:
192.168.1.300
I can't stop laughing from that one !
Yeah I can't figure out why it didn't work. 2^8 = 300
_az
June 6, 2021, 5:02am
9
LMAO sorry, I really didn't realize.
It took a while but I finally got a Linux VM running with NGINX (I'll just call it NGINX for brevity henceforth). I've tried researching reverse proxies but something is still off and I'm not sufficiently knowledgeable of how all of this works:
Router is directing all Port 80 and 443 traffic to NGINX.
NGINX is at 192.168.1.120
NGINX is pingable from any computer within the LAN.
Owncloud appliance VM is at 192.168.1.121.
My main Linux Apache webserver has 2 websites: (192.168.1.227)
mno.org
s7.org
When I try to access either https://mno.org or https://s7.org , they go to:
mno.org --> "Welcome to nginx!"
s7.org --> mno.org
What did I configure improperly? Oh and I did execute Let's Encrypt per your instructions. It did change a few entries.
nginx.cfg (domains changed to protect the innocent)
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss t$
# Virtual Host Configs
#added by Jones
listen 80;
server_name s7.space;
proxy_pass http://129.168.1.121;
listen 80;
server_name owncloud.s7.space;
listen 80;
listen 443 ssl;
server_name s7.org;
proxy_pass http://192.168.1.227;
ssl_certificate /etc/letsencrypt/live/s7.org/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/s7.org/privkey.pem; # managed by Certbot
listen 80;
listen 443 ssl;
server_name mno.org;
ssl_certificate /etc/letsencrypt/live/mno.org/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/mno.org/privkey.pem; # managed by Certbot
if ($host = s7.org) {
} # managed by Certbot
listen 80;
server_name s7.org;
if ($host = mno.org) {
listen 80;
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
rg305
June 7, 2021, 12:05am
12
You should not set vhost configs to listen to both 80 & 443.
_az
June 7, 2021, 12:14am
13
Apart from the duplicate 80 virtual hosts, I think these are probably fine. Certbot's nginx installer joins them automatically if you choose not to enable redirects.
But if you want the HTTP->HTTPS redirects to apply, it's best to remove the port 80 from those dual 80/443 vhosts.
That config looks like it should work just fine for those two domains.
Is nginx definitely reloaded?
sudo nginx -t
sudo nginx -s reload
I removed the lines referencing 443 and now:
mno.org connects securely to nginx but shows "welcome to nginx!" instead of the mno.org on the other server.
s7.org seems to forward to mno.org , showing "welcome to nginx!".
It doesn't seem to be redirecting traffic to the other linux apache server, which btw was already set up with Let's Encrypt to accept HTTPS traffic. It's configured with multiple sites.
I guess I wasn't reloading it properly. But it's saying:
nginx: [warn] conflicting server name "mno.org" on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name "s7.org" on 0.0.0.0:80, ignored
Should that location / { proxy_pass statement be moved into where Let's Encrypt created an entry?
_az
June 7, 2021, 12:27am
16
If you followed @rg305 's earlier advice, I'm not sure why you would be seeing those duplicate warnings.
What's the full output of nginx's config; not just that file:
sudo nginx -T
user www-data;
pid /run/nginx.pid;
events {
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
# SSL Settings
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
listen 80;
listen 80;
server_name s7.org;
listen 80;
server_name s7.org;
listen 80;
#mail {
# server {
# protocol pop3;
# proxy on;
# server {
# protocol imap;
# proxy on;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
listen 80 default_server;
# SSL configuration
root /var/www/html;
server_name _;
try_files $uri $uri/ =404;
#location ~ \.php$ {
# include snippets/fastcgi-php.conf;
# # With php-fpm (or other unix sockets):
# fastcgi_pass unix:/var/run/php/php7.4-fpm.sock;
# # With php-cgi (or other tcp sockets):
# fastcgi_pass 127.0.0.1:9000;
# concurs with nginx's one
#location ~ /\.ht {
# deny all;
#server {
# listen 80;
# listen [::]:80;
# server_name example.com;
# root /var/www/example.com;
# index index.html;
# location / {
# try_files $uri $uri/ =404;
# SSL configuration
root /var/www/html;
server_name mno.org; # managed by Certbot
#location ~ /\.ht {
# deny all;
listen 80 ;
listen [::]:80 ;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
ssl_prefer_server_ciphers off;
ssl_ciphers "replaced..................";
_az
June 7, 2021, 12:51am
18
Was there another line between these two lines, in the output originally? Assuming there was, and that missing line was:
# configuration file /etc/nginx/sites-enabled/default:
Then I think you should be able to:
sudo rm /etc/nginx/sites-enabled/default
and then:
Delete this.
Add these lines inside:
listen 443 ssl;
include /etc/letsencrypt/options-ssl-nginx.conf;
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem;
Add those same lines there.
and then try reload nginx.
Directory deleted.
Yes, that line was missing because I was cutting/pasting one screen at a time but the dump below now shows everything after changes, in one continuous copy/paste.
I reloaded nginx per previous instruction.
When I try to visit https://mno.org it says "mno.org redirected you too many times."
https://s7.org redirects to https://mno.org and does the preceding bullet.
Did I properly effect all the changes you stated? (sudo nginx -T below)
user www-data;
pid /run/nginx.pid;
events {
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
# SSL Settings
# Logging Settings
# Gzip Settings
gzip on;
# gzip_vary on;
# gzip_proxied any;
#added by WebGuy
#server {
# listen 80;
# server_name s7.space;
# location / {
# proxy_pass http://129.168.1.121;
listen 80;
server_name s7.org;
listen 443 ssl;
include /etc/letsencrypt/options-ssl-nginx.conf; # added
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # added
listen 443 ssl;
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # edded
listen 80;
server_name s7.org;
listen 80;
#mail {
# server {
# protocol pop3;
# proxy on;
# server {
# protocol imap;
# proxy on;
types {
text/css css;
text/xml xml;
image/gif gif;
text/mathml mml;
text/plain txt;
image/png png;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/webp webp;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
video/mp2t ts;
video/mp4 mp4;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-wmv wmv;
# this file.
ssl_ciphers "----------";
_az
June 7, 2021, 3:32am
20
Is it correct that mno.org and s7.org have the same proxy_pass IP address? If so, you might want to add this just above the proxy_pass lines:
proxy_set_header Host $host;
(Edit: actually, do this in any case. It's just better).
Other than that, this looks good.
Ah, good point.
You will want to get rid of the HTTP-to-HTTPS redirect on your other webservers now. This is because HTTPS is now handled at the nginx proxy rather than on each of the internal webservers.
What are you running on those? Apache?
