Certbot with Apache and ACME v2 Error
www.cert-bot.com
sudo certbot --authenticator webroot --installer apache --server https://acme-v02.api.letsencrypt.org/directory
Plugins selected: Authenticator webroot, Installer apache
Enter email address (used for urgent renewal and security notices) (Enter ‘c’ to
cancel): xxx@gmail.com
An unexpected error occurred:
File “/usr/lib/python3/dist-packages/acme/messages.py”, line 204, in getitem
return self._jobj[self._canon_key(name)]
KeyError: ‘new-reg’
KeyError: ‘Directory field not found’
Debian 9
GCP
Yes
not sure but likely no
What version of Certbot is that?
sudo certbot --version
ACMEv2 support was added in 0.22.0. I’m not certain, but that error message looks about like how I would expect an older version of Certbot to react to the new server.
thanks for replying.
certbot 0.21.1
I used this command to install
sudo apt-get install python-certbot-apache -t stretch-backports
How do I install v0.22 ?
@mnordhoff
Like what you suspected, it is the version issue.
I have since removed the existing v0.21 installation and installed v0.22 and it is working without issue.
Thank you for helping.
