lease fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | example.com), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
randoblazer.com
sudo certbot renew
Processing /etc/letsencrypt/renewal/randoblazer.com.conf
Renewing an existing certificate for randoblazer.com
Domain: randoblazer.com
Detail: x.x.x.x: Invalid response from http://randoblazer.com/.well-known/acme-challenge/Ojuwdp8NuhJMZrCPAsiFHHfG4a85-72yBduug6e-r8A: 404
Failed to renew certificate randoblazer.com with error: Some challenges have failed.
/etc/letsencrypt/live/randoblazer.com/fullchain.pem (failure)
nginx version: nginx/1.18.0 (Ubuntu)
Ubuntu 22.04
AWS
Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.6.0
