My domain is: breeze.ggt.bz, co.ggt.bz, several other subdomains
I ran this command: sudo certbot renew
Processing /etc/letsencrypt/renewal/breeze.ggt.bz.conf
Renewing an existing certificate for breeze.ggt.bz
Domain: breeze.ggt.bz
Detail: During secondary validation: 45.137.206.17: Invalid response from https://nyc1.breeze.ggtyler.dev/: "<!DOCTYPE html><html><head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\"><title>About | BreezeWiki</title>"
Processing /etc/letsencrypt/renewal/co.ggt.bz.conf
Renewing an existing certificate for co.ggt.bz
Domain: co.ggt.bz
Detail: 45.137.206.17: Invalid response from https://co.ggt.bz/.well-known/acme-challenge/4eDu__4siL33f42YysHEMx1PGeoI3NXtDQxg1xMgu_Q: 500
Failed to renew certificate co.ggt.bz with error: Some challenges have failed.
My web server is (include version): nginx v1.18.0
The operating system my web server runs on is (include version): Ubuntu 22.04
My hosting provider, if applicable, is: Royale Hosting
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 3.0.1
Here are the two configs for the domains I'm trying to renew. There are some others that aren't renewing but they have near identical configs and the same errors.
server_name breeze.ggt.bz;
#error_log /var/log/nginx/ggt.bz.error.log;
ssl_certificate /etc/letsencrypt/live/breeze.ggt.bz/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/breeze.ggt.bz/privkey.pem;
proxy_pass http://localhost:58008;
proxy_redirect off;
proxy_set_header Host $host;
proxy_http_version 1.1;
if ($host = breeze.ggt.bz) {
listen 80;
server_name co.ggt.bz;
ssl_certificate /etc/letsencrypt/live/co.ggt.bz/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/co.ggt.bz/privkey.pem;
proxy_redirect off;
if ($host = co.ggt.bz) {
listen 80;
But there is useful information in there, the redirects
HTTPCheck
Debug
Requests made to the domain
Request to: breeze.ggt.bz/45.137.206.17, Result: [Address=45.137.206.17,Address Type=IPv4,Server=nginx/1.18.0 (Ubuntu),HTTP Status=301,Number of Redirects=4,Final HTTP Status=200], Issue:
Trace:
@0ms: Making a request to http://breeze.ggt.bz/.well-known/acme-challenge/letsdebug-test (using initial IP 45.137.206.17)
@0ms: Dialing 45.137.206.17
@223ms: Server response: HTTP 301 Moved Permanently
@223ms: Received redirect to https://breeze.ggt.bz/.well-known/acme-challenge/letsdebug-test
@223ms: Dialing 45.137.206.17
@563ms: Server response: HTTP 302 Found
@563ms: Received redirect to https://ggt.bz/breeze
@598ms: Dialing 45.137.206.17
@935ms: Server response: HTTP 302 Found
@935ms: Received redirect to https://breeze.ggtyler.dev
@1172ms: Dialing 45.137.206.17
@1509ms: Server response: HTTP 301 Moved Permanently
@1509ms: Received redirect to https://nyc1.breeze.ggtyler.dev/
@1543ms: Dialing 45.137.206.17
@1886ms: Server response: HTTP 200 OK
Starting here http://breeze.ggt.bz/.well-known/acme-challenge/letsdebug-test ends up several redirects later here https://nyc1.breeze.ggtyler.dev/. Then returns a response of HTTP 200 OK for something likely nonexistent 404 Not Found - HTTP | MDN
Certbot isn't the one following the redirects. The Let's Encrypt auth server does. Redirects are not ideal but are supported: Challenge Types - Let's Encrypt
But, please see my post describing that with the --nginx plugin authenticator we shouldn't be seeing redirects at all.
Yes, sorry, you posted your reply right before I did mine.
IP is easy: 45.137.206.17
I have a lot of server blocks though. For some reason, it's not letting me write to a file?
ā ~ sudo nginx -T >> nginx-blocks.log
Oh, I see there is a VERY large number of server blocks
The Certbot --nginx option makes a temp change to your nginx config and then reloads nginx asynchronously. By default, it only waits 1 second and then tells the LE server to make the challenge.
If your nginx takes longer than 1s to reload it won't have the effective changes by the time the challenge arrives from the LE server and will fail. Which is what I think is happening here.
Yes, haha. I share the server between 4 other people and I have a multitude on stuff running on there, plus the shortening script, plus redirects from the regular subdomains to the server-specific subdomain.
With that being said, I'm still getting the same result:
Simulating renewal of an existing certificate for co.ggt.bz
Domain: co.ggt.bz
Detail: 45.137.206.17: Invalid response from https://co.ggt.bz/.well-known/acme-challenge/yv0mdw_wk7lJkK2-H50qMj_LUI-ZKQYJG9_0Oxg486k: 500
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/co.ggt.bz/fullchain.pem (failure)
Oh, I think it is because of the stray return 301 ... that is not inside a location block.
Remove the line below your listen 80; because the 'if' statement handles redirect anyway. The return not inside a location block is overriding the return 200 ... that is inside a location block.
This is your server block from the log after the temp change. Just fyi
server {rewrite ^(/.well-known/acme-challenge/.*) $1 break; # managed by Certbot
listen 80;
location = /.well-known/acme-challenge/Y33Yh1Fei8gHfyT-DaXEYohmZccjQM_g734xVAaSN04{default_type text/plain;return 200 Y33Yh1Fei8gHfyT-DaXEYohmZccjQM_g734xVAaSN04.lbrqEaZlbnGQ1RxX4qFxjhlB_b96-zY8DLtOTQvYWZI;} # managed by Certbot
