Im using React and Nginx
My domain is: oraj.bjmp.gov.ph
I ran this command: sudo certbot --nginx -v -d oraj.bjmp.gov.ph --debug-challenges
Certificate is due for renewal, auto-renewing...
Renewing an existing certificate for oraj.bjmp.gov.ph
http-01 challenge for oraj.bjmp.gov.ph
Challenges loaded. Press continue to submit to CA. Pass "-v" for more info about
challenges.
Press Enter to Continue
Challenge failed for domain oraj.bjmp.gov.ph
Domain: oraj.bjmp.gov.ph
Detail: 202.90.133.189: Invalid response from http://oraj.bjmp.gov.ph/.well-known/acme-challenge/CE14KPqHdW2ZuvjnmyKzDNAqMC78x0yVtge2_TQupS0: 404
My web server is (include version): nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 22.04.2 LTS
My hosting provider, if applicable, is: Im on-premises
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): No, using SSH client only
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
I tested the site on letsdebug.net and is All Ok
This is site config file
upstream backend {
server localhost:3000;
server_name oraj.bjmp.gov.ph;
proxy_pass http://backend/;
proxy_http_version 1.1;
proxy_set_header Connection "upgrade";
proxy_set_header Host $http_host;
proxy_set_header X-Forward-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forward-Proto http;
proxy_set_header X-Nginx-Proxy true;
proxy_redirect off;
ssl_certificate /etc/letsencrypt/live/oraj.bjmp.gov.ph/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/oraj.bjmp.gov.ph/privkey.pem; # managed by Certbot
if ($host = oraj.bjmp.gov.ph) {
} # managed by Certbot
listen 80;
