certbot renew
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Processing /usr/local/etc/letsencrypt/renewal/mecadtron.de.conf - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Saving debug log to /var/log/letsencrypt/letsencrypt.log Unable to read ssl_module file; not disabling session tickets. Renewing an existing certificate for mecadtron.de and [www.mecadtron.de](http://www.mecadtron.de) Certbot failed to authenticate some domains (authenticator: apache). The Certificate Authority reported these problems: Domain: mecadtron.de Type: connection Detail: 95.217.187.226: Fetching http://mecadtron.de/.well-known/acme-challenge/RlBQenTXFFhC0qT8wWoHx0YSchyo44XgKg4COYXzezM: Connection refused Domain: [www.mecadtron.de](http://www.mecadtron.de) Type: connection Detail: 95.217.187.226: Fetching http://www.mecadtron.de/.well-known/acme-challenge/00Won9vFVkPeaDN1nT6Eq3zYKmX_7CtqRnB_RioNbRk: Connection refused Hint: The Certificate Authority failed to verify the temporary Apache configuration changes made by Certbot. Ensure that the listed domains point to this Apache server and that it is accessible from the internet. Error while running apachectl graceful. apache24 not running? (check /var/run/httpd.pid). Unable to restart apache using ['apachectl', 'graceful'] Encountered exception during recovery: certbot.errors.MisconfigurationError: Error while running apachectl graceful. apache24 not running? (check /var/run/httpd.pid). Failed to renew certificate mecadtron.de with error: Some challenges have failed. - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - All renewals failed. The following certificates could not be renewed: /usr/local/etc/letsencrypt/live/mecadtron.de/fullchain.pem (failure) - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 1 renew failure(s), 0 parse failure(s) Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
apache 2.4.56 (FreeBSD
FreeBSD FreeBSD 13.2-RELEASE releng/13.2-n254617-525ecfdad597 GENERIC amd64
no
1.22.0
The certbot renew used to work for years. There was no manual change in the configuration, rather than an upgrade of apache from 2.4.54.
In the cletsencrypt.log file I can see that the script tries to read the mod_ssl.so file from
/usr/local/etc/apache24/libexec/apache24/mod_ssl.so
rather than from
/usr/local/libexec/apache24/mod_ssl.so
where it resides. Where does this change come from and what information uses certbot to search for the file?
