Hello,
Under Ubuntu 16.04 + Apache 2.4.18, when trying to renew with Certbot installed from repository:
# letsencrypt renew --agree-tos --dry-run
I see the below:
Processing /etc/letsencrypt/renewal/example.com.conf
2016-12-08 20:13:38,723:WARNING:letsencrypt.client:Registering without email!
2016-12-08 20:13:47,220:ERROR:letsencrypt.le_util:Error while running a2dismod socache_shmcb.
ERROR: The following modules depend on socache_shmcb and need to be disabled first: ssl
2016-12-08 20:13:47,221:ERROR:letsencrypt.reverter:Unable to run undo command: a2dismod socache_shmcb
** DRY RUN: simulating 'letsencrypt renew' close to cert expiry
/etc/letsencrypt/live/example.com/fullchain.pem (success)
- Your account credentials have been saved in your Let's Encrypt
also contain certificates and private keys obtained by Let's
Encrypt so making regular backups of this folder is ideal.
Will renewal actually happen if the above is run via Cron on proper date?
If not, what are my options apart from doing that manually?
Thanks.
