My domain is: joyal.in
It produced this output: not up for renewal
My web server is (include version): Apache 2.4.18
The operating system my web server runs on is (include version): Ubuntu 16.04 Xenial
My hosting provider, if applicable, is: Ramnode
Hi @JoyalV
Can you explain a bit more
After which update are certificates not showing?
I can see you have issued a certificate 12 days ago. crt.sh | joyal.in
can you also paste the output of the command
certbot certificates
Andrei
If you go to the domain it doesn’t show you the issued certs
This is what I see when I try to reinstall https://ibb.co/exMTYF
hi @JoyalV
Did you read the error message?
The answer is pretty well spelt out - apache doesn’t start as something else is using port 80
You should be able to use the netstat command to figure out what process it is and fix it.
Andrei
