/etc/nginx/snippets/snakeoil.conf:ssl_certificate_key /etc/ssl/private/ssl-cert-snakeoil.key;
Then you havenāt finished the configuration.
The cert is there [valid 82 more days].
wdym?
The whole thing is this:
"web": {
"host": "0.0.0.0",
"listen": 8080,
"ssl": {
"enabled": true,
"certificate": "/etc/letsencrypt/live/s1.prismforge.com/fullchain.pem",
"key": "/etc/letsencrypt/live/s1.prismforge.com/privkey.pem"
"docker": {
"container": {
"user": null
"network": {
"name": "pterodactyl_nw"
"socket": "/var/run/docker.sock",
"autoupdate_images": true
"filesystem": {
"server_logs": "/tmp/pterodactyl"
"internals": {
"disk_use_seconds": 30,
"set_permissions_on_boot": true,
"throttle": {
"enabled": true,
"kill_at_count": 5,
"decay": 10,
"lines": 1000,
"check_interval_ms": 100
"sftp": {
"path": "/srv/daemon-data",
"ip": "0.0.0.0",
"port": 2022,
"keypair": {
"bits": 2048,
"e": 65537
"logger": {
"path": "logs/",
"src": false,
"level": "info",
"period": "1d",
"count": 3
"remote": {
"base": "http://admin2.prismforge.com"
"uploads": {
"size_limit": 100
"keys": [
"(Replaced this cause idk if secret or not lol)"
You can remove that.
Yes KEYS are always private! [donāt show ever]
I mean you havenāt finished the steps on the tutorial.
The cert is ready.
Now you just need to use it.
Or if all is configuredā¦ restart the system/container?
systemctl restart nginx ?
Cert was configured 8 days ago and working at the time. It randomly stopped today, because the previous cert was supposed to expire today.
And I tried to run systemctl restart nginx, and it gave me an error:
Job for nginx.service failed because the control process exited with error code.
See "systemctl status nginx.service" and "journalctl -xe" for details.
Please show:
nginx -t
and also:
ā nginx.service - A high performance web server and a reverse proxy server
Loaded: loaded (/lib/systemd/system/nginx.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2019-10-27 10:59:34 PDT; 3min 17s ago
Docs: man:nginx(8)
Process: 17407 ExecStop=/sbin/start-stop-daemon --quiet --stop --retry QUIT/5 --pidfile /run/nginx.pid (code=exited, status=0/SUCCESS)
Process: 13992 ExecStart=/usr/sbin/nginx -g daemon on; master_process on; (code=exited, status=0/SUCCESS)
Process: 17408 ExecStartPre=/usr/sbin/nginx -t -q -g daemon on; master_process on; (code=exited, status=1/FAILURE)
Main PID: 13999 (code=exited, status=0/SUCCESS)
Oct 27 10:59:34 client-03-rs systemd[1]: Starting A high performance web server and a reverse proxy server...
Oct 27 10:59:34 client-03-rs nginx[17408]: nginx: [emerg] BIO_new_file("/etc/letsencrypt/live/<domain>/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/<domain>/fullc
Oct 27 10:59:34 client-03-rs nginx[17408]: nginx: configuration file /etc/nginx/nginx.conf test failed
Oct 27 10:59:34 client-03-rs systemd[1]: nginx.service: Control process exited, code=exited status=1
Oct 27 10:59:34 client-03-rs systemd[1]: nginx.service: Failed with result 'exit-code'.
Oct 27 10:59:34 client-03-rs systemd[1]: Failed to start A high performance web server and a reverse proxy server.
root@client-03-rs:~# nginx -t
nginx: [emerg] BIO_new_file("/etc/letsencrypt/live/<domain>/fullchain.pem") failed (SSL: error:02001002:system library:fopen:No such file or directory:fopen('/etc/letsencrypt/live/<domain>/fullchain.pem','r') error:2006D080:BIO routines:BIO_new_file:no such file)
Does it actually say "<domain>" or you changed it to that?
it says domain, let me fix it
I donāt see how we missed that file beforeā¦
Where is it located?
Please show that file (using ssl_certificate
ls -l /etc/letsencrypt/live/
before what?
You're making changes and not saying anything about making them nor what you are changing.
-rw-r--r-- 1 root root 740 Jul 29 10:41 README
drwxr-xr-x 2 root root 4096 Oct 19 12:53 s1.prismforge.com
This is the copy and paste format for it:
server_tokens off;
Replace all with admin2.prismforge.com? or s1.prismforge.com
listen 80;
server_name <domain>;
return 301 https://$server_name$request_uri;
listen 443 ssl http2;
root /var/www/pterodactyl/public;
index index.php;
access_log /var/log/nginx/pterodactyl.app-access.log;
error_log /var/log/nginx/pterodactyl.app-error.log error;
# allow larger file uploads and longer script runtimes
client_max_body_size 100m;
client_body_timeout 120s;
sendfile off;
# SSL Configuration
ssl_certificate /etc/letsencrypt/live/<domain>/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/<domain>/privkey.pem;
ssl_session_cache shared:SSL:10m;
ssl_protocols TLSv1.2;
ssl_ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256';
ssl_prefer_server_ciphers on;
# See https://hstspreload.org/ before uncommenting the line below.
# add_header Strict-Transport-Security "max-age=15768000; preload;";
add_header X-Content-Type-Options nosniff;
add_header X-XSS-Protection "1; mode=block";
add_header X-Robots-Tag none;
add_header Content-Security-Policy "frame-ancestors 'self'";
add_header X-Frame-Options DENY;
add_header Referrer-Policy same-origin;
try_files $uri $uri/ /index.php?$query_string;
location ~ \.php$ {
fastcgi_split_path_info ^(.+\.php)(/.+)$;
fastcgi_pass unix:/run/php/php7.2-fpm.sock;
fastcgi_index index.php;
include fastcgi_params;
fastcgi_param PHP_VALUE "upload_max_filesize = 100M \n post_max_size=100M";
fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
fastcgi_param HTTP_PROXY "";
fastcgi_intercept_errors off;
fastcgi_buffer_size 16k;
fastcgi_buffers 4 16k;
fastcgi_connect_timeout 300;
fastcgi_send_timeout 300;
fastcgi_read_timeout 300;
include /etc/nginx/fastcgi_params;
location ~ /\.ht {
deny all;
before I had it as this: with admin2.prismforge.com as the domain
sorry didnāt say I changed it
listen 80;
index index.html index.htm index.php;
charset utf-8;
location = /favicon.ico { access_log off; log_not_found off; }
location = /robots.txt { access_log off; log_not_found off; }
access_log off;
sendfile off;
location ~ \.php$ {
location ~ /\.ht {
deny all;
Which name will you be using at?:
Oh, and changing it fixed the error with
but the connection still isnāt working
for
Iām not sure because I donāt know what it means.
What I do know, is that admin2.prismforge.com is the url to login
And s1.prismforge.com is the node that my Minecraft serverās connect to
Then that is probably the "domain" in the file above.
As for the MC node, wasn't there some file referencing port 8080 or something like that?
Are there instructions for any other files to use the cert in?
For the configās that I have to change, no. Itās only the copy and paste for
/srv/daemon/config/core.json
And the
/etc/nginx/sites-available/pterodactyl.conf
Both of which have already been sent.
(I can no longer reply to posts, so I have to edit the last one)
The 8080 is the /srv/daemon/config/core.json
"web": {
"host": "0.0.0.0",
"listen": 8080,
"ssl": {
"enabled": true,
"docker": {
"container": {
"user": null
"network": {
"filesystem": {
"internals": {
"throttle": {
"enabled": true,
"kill_at_count": 5,
"decay": 10,
"lines": 1000,
"sftp": {
"ip": "0.0.0.0",
"port": 2022,
"keypair": {
"bits": 2048,
"e": 65537
"logger": {
"path": "logs/",
"src": false,
"level": "info",
"period": "1d",
"count": 3
"remote": {
"uploads": {
"size_limit": 100
"keys": [
You can PM me directly or open another account and use that new account to continue posting here.
[click my icon and choose message]
